Old 06-04-2010   #1
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Boost leak test
I need someone who has the tools to do a boost leak test to help me out please. DB is a trek for me, and MAP said they won't be able to do it until july.. kinda odd, anyway. I'll give you like $20 if you can help me out. I'm free after 5ish pm this evening.
Old 06-04-2010   #2
Re: Boost leak test
What turbo do you have on it?
The tool is really easy to make and then you could do it whenever you wanted. You could use my 4" tester for a while if you have a turbo with a 4" inlet.
Old 06-04-2010   #3
Re: Boost leak test
I have a 4" tester and one for a 16g sized inlet if you have a 3" turbo and a 3" coupler we might be able to figure something out with all the crap i have laying around.
Old 06-04-2010   #4
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: Boost leak test
I just made one, it's for a 3" inlet. Post up ur turbo inlet like others have said and go from there. I think mine was under 4 bux to make.
Old 06-04-2010   #5
Speedfreak
Drives: four tires
Re: Boost leak test
He's got a 14b on his 2g.
Old 06-04-2010   #6
viridionplague
Re: Boost leak test
ive got a tester to fit a 14b
Old 06-04-2010   #7
Re: Boost leak test
^Same here.
I'll be home for a few hours working outside so now is a good time.
Old 06-04-2010   #8
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Re: Boost leak test
Thanks guys, I'm going to just make a tester tonight since I'll probably need one in the future as well and I've got someone to provide the other stuff (compressor, etc).
I'm assuming a pvc end cap that fits the 14b 2.25"? coupler should work fine?
Thanks for the offerings.
Old 06-04-2010   #9
Re: Boost leak test
Yep, i think vfaq has good instructions on making one, if you can use a Tbolt clamp instead of a hose clamp, but its not necessary
Old 06-09-2010   #10
C89ZX7R
C89ZX7R's Avatar
Drives: 87 and 89 Chrysler Conquest
Re: Boost leak test
http://www.youtube.com/watch?v=atretf9u-Mc&hd=1
Motor Is Tight, Sounds Unbelievably Badass, Intimidates Slow Hondas Instantly
C89ZX7R is offline   Reply With Quote
Old 06-09-2010   #11
Re: Boost leak test
Umm, not sure why you would disconnect it from the intake manifold though... It's always good to have that pressurized too to check for leaks around the throttle body and flange to the head.
