Old 09-09-2010   #1
91TalonTSSEi
Drives: 91 TSi, 02 SSEi
91 talon won't go over 30mph/2500 rpms in a forward gear
hey all. I have a 91 talon TSi awd auto. I bought the car in rough shape and have been trying to get it close to drivable. In 1st, 2nd, or Drive the car will move very sluggish. With my foot to the floor i get about 2500 rpms.It has no problems getting to that point, it just wont' go anymore. The car has a supposed rebuilt transmission in it. I have full revs in neutral , dont know if that is important or not. Any idea on where to start? Also pulling codes from TCU and ECU show only constant short beeps....a normal condition correct?
Thanks in advance,
James
91TalonTSSEi is offline   Reply With Quote
Old 09-09-2010   #2
way2fastalon
IS Broken :-/
way2fastalon's Avatar
Re: 91 talon won't go over 30mph/2500 rpms in a forward gear
torque converter / stuck in a gear. what dose it do dose it shift normal ?
what dose the trans fluid look like is it empty or overfilled autos are picky cars
1991 Eagle Talon awd
2.0 fully built lower-end
+more mods to list
Old 09-09-2010   #3
91TalonTSSEi
transmission is fine up too 30mph..can't go anyfaster..almost like it is hitting a wall. Transmission fluid level is dead on and it's a nice red with no burnt smell.
one recommendation is a boost leak past the MAF? Could the ecu be freaking out..i'm gonna do a boost test regardless but just making sure it's possible.
James
Old 09-09-2010   #4
CarPsyco84
CarPsyco84's Avatar
Sounds like the MAF is not working or not plugged in...
-When in doubt, Moar RPM.
Old 09-10-2010   #5
91TalonTSSEi
i'll definitely double check but wouldn't that throw a code? or and i expecting too much from a 91 ECU?
james
Old 09-12-2010   #6
CarPsyco84
CarPsyco84's Avatar
james
It should if its not plugged in. I've seen catalytic's clog up so bad that cars wont rev up, but thats pretty unlikely, your a/f is usually way off which is why it won't rev up, so check the fuel pressure regulator maybe?
Old 09-12-2010   #7
91TalonTSSEi
alright i checked the maf..it was plugged in..went over all the charge piping and it's all nice and tight now.Didn't get a chance to drive it yesterday(gf's birthday) so I'll check the FPR and see what it does today.
thanks
James
Old 09-12-2010   #8
viridionplague
when i had a similar problem in my 92, it was a bad maf. maybe try borrowing a maf and throwing it in.
it would happen as soon as the car started making boost at about 2500 rpm. i could get it above 2500 with very very light throttle so the car was always pulling vacuum. but anything past that would be instant wall.
