Old 11-18-2010   #1
Boostn2g
Boostn2g's Avatar
Drives: 2g Talon
How big of a drop, 2G
Ok I wanna lower the car with new suspension all around. I wanna know whats the biggest drop I can do without needing new rear camber adjustment arms?
Thanks
Alex
Red 1995 Eagle Talon TSI-Original California car-
-Stock
-5SPD FWD
-T28 Turbo
-3'' HKS catback
-K&N
-1G BOV
-225/50/16s
-151k -waiting on 7 bolt to blow-
Boostn2g is offline   Reply With Quote
Old 11-18-2010   #2
Re: How big of a drop, 2G
Drop it likes it hot!!
I believe any drop will require a camber kit if you wanted it perfect, but I think a 1.3" drop like with Pro-kits is a low as you can get before you SHOULD get a camber kit, but every car seems to be different.
Good luck.
Old 11-18-2010   #3
Fixing the rear camber in a 2g is almost free, just 8 longer bolts and washers, probably $15 in hardware.
Old 11-18-2010   #4
x2. My car isn't crazy, crazy low but feel like its kind of low for a 2g and with a couple washer and longer bolts the alignment shop said it was inspec.
Old 11-18-2010   #5
I liked my 2" drop on my 2G. But 2" was more than the stock adjustments could correct for. So like mentioned above, I did the $15 rear camber kit and all was good.
Old 11-19-2010   #6
Boostn2g
Boostn2g's Avatar
Drives: 2g Talon
Is there a write up on this somewhere? i'm shopping for suspension as we speak.
-Stock
-5SPD FWD
-T28 Turbo
-3'' HKS catback
-K&N
-1G BOV
-225/50/16s
Old 11-19-2010   #7
Prolly on tuners or something. Just search something on there like 2G rear camber kit bolts washers.
Old 11-19-2010   #8
There is a how to on vfaq.com
Old 11-19-2010   #9
Boostn2g
Boostn2g's Avatar
Drives: 2g Talon
Thanks! Ill be dropping my 2g this weekend!
-Stock
-5SPD FWD
-T28 Turbo
-3'' HKS catback
-K&N
-1G BOV
-225/50/16s
Old 11-20-2010   #10
Archertsi
Archertsi's Avatar
Drives: 1995 talon tsi
I had problems re-adjusting the rear toe in mine back when it was slammed. The stock eccentrics did not adjust far enough so I replaced them with some turnbuckles that I made.
Just keep it in mind as far as how low you go, I ran out at 2 inches of drop
@BloodSweatMotorwerks
Old 11-20-2010   #11
Boostn2g
Boostn2g's Avatar
Drives: 2g Talon
I wanna drop 2''... those washers wont go that far?
-Stock
-5SPD FWD
-T28 Turbo
-3'' HKS catback
-K&N
-1G BOV
-225/50/16s
Old 11-20-2010   #12
Archertsi
Archertsi's Avatar
The washers will go plenty far to correct the camber. Im talking about the rear toe alignment, it will change so the tires will no longer be pointed striaght forward. They will both be pointing outward until you get an alignment. The alignment shop may find that you do not have enough adjustment to correct it with the stock eccentrics.
Old 11-20-2010   #13
BriK
BriK's Avatar
Drives: GG IX MR SE
^^^ What suspension setup did you go with? Springs and shocks? With 2" of drop, I'd assume the factory shocks will be bouncy.
BriK is offline   Reply With Quote
Old 11-20-2010   #14
Boostn2g
Boostn2g's Avatar
Drives: 2g Talon
I see. Well my work got shut down, I got laid off and haven't received a paycheck for a week yet, i would like to purchase my setup soon, I suppose ill just have to wait and see when there on the car, thanks for the feedback! I'm goin cheap/ KYB GR2 struts and 2'' drop ebay springs
http://cgi.ebay.com/ebaymotors/ws/eB...ht_3932wt_1058
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_500wt_1182
-Stock
-5SPD FWD
-T28 Turbo
-3'' HKS catback
-K&N
-1G BOV
-225/50/16s
Old 11-21-2010   #15
LingLing
AznKraut
LingLing's Avatar
I wouldn't use any ebay suspension parts on any car. Spend the money on good suspension components your car and your pocket book will thank you later. Just my .02.
