Old 04-01-2014   #1
dsmDolney
dsmDolney's Avatar
Drives: Racecars
operation redo engine bay
So after getting this 2g and looking at the bay and seeing the paint coming off and the padding on the fire wall that is ugly i decided to pull the motor and repaint and fix the strut tower since i picked up my daily driver this past saturday so i can finally get started on it.
ID:	14282   Click image for larger version
Tyler
2011 Subaru Sti 11.0 @135mph
Old 04-01-2014   #2
b00sted_spyder
Re: operation redo engine bay
In my opinion, I think the engine bay color should be the same as the exterior color. That strut tower looks very scary and should be fixed asap.
Old 04-01-2014   #3
dsmDolney
dsmDolney's Avatar
Drives: Racecars
I am thinking about it going red also it would look better and thats the number one priority right now pull the motor and fix the strut tower any easy but good ways to fix them does anyone know ?? Or do i just have to cut it out and weld metal back in
Tyler
Old 04-01-2014   #4
With it looking that bad I would look for a good non rusty tower and replace the full thing.
Old 04-01-2014   #5
mark4g63t
mark4g63t's Avatar
Drives: 95 Talon TSI
Ive got a red one
BW8776, e-85
Old 04-01-2014   #6
dsmreck
dsmreck's Avatar
Drives: 98 gsx
It really does depend on how bad it is, and that looks pretty bad. The thing about it is there are two layers of metal so u will need to start grinding the top and bottom to see how far it goes and cut out all the rust. Than you would want a sealer and paint inbetween and all around everything that's left after cutting and grinding. Step five would be to fab up a top and bottom layer to be welded into place. One at a time so you can use the sealer inbetween. Than bondo and paint. Ask dark2g questions if you need further help or explainations on rust and how to treat it, he is the man at body work.
Old 04-02-2014   #7
Dark2g
Drives: 2gb gsx
That is pretty bad on the tower. I would get a spot weld cutter and find a new tower if u want it to be structurally sound. The rust will be everywhere between the layers of steel. Strut tower rust and rear quarter rust on these cars is pretty normal cause mitsu sucked at sealing the wheel wells
Old 04-02-2014   #8
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Just doing an update got home early from work today so started taking suspention stuff off the front to go and get powdercoated from my neighbor also been just taking simple stuff off to get ready to pull the engine hopefully have that pulled saturday (if its nice enough out)
Also found a good place for my parts (in my room)
Tyler
Old 04-02-2014   #9
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
I put spare parts in my spare bedroom as well, if they are clean lol
2006 WW IX RS 396/404 - SOLD
Old 04-02-2014   #10
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Its a good place for them not to get beat up and no one to touch them but soon i wont have anywhere to walk in my room lol
Tyler
Old 04-02-2014   #11
mark4g63t
mark4g63t's Avatar
Thats when the basement comes into play...Then soon enough you'll get kicked out the house or paying rent + storage fees lol
BW8776, e-85
Old 04-02-2014   #12
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Ha ha yea no kidding soon its all going to be in the hallway that leads to my room and i still cant beleive i havnt gotten kicked out of the garage yet considering im starting another mess lol
Tyler
Old 04-03-2014   #13
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Got some more work done tonight got the motor out and now time to tackle the hard part fixing the tower rust theres some pics of pulling it
ID:	14301   Click image for larger version
Tyler
Old 04-04-2014   #14
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Some updated pics got the bay pretty much stripped and almost ready to attack the strut tower
Tyler
Old 04-07-2014   #15
dsmDolney
dsmDolney's Avatar
Drives: Racecars
picked up a mostly complete strut tower from mark4g63t last night plan on cutting mine out of what I need to cut then trace it on the good tower cut and weld into place hopefully get this done soon it kills not being able to drive a nice car in this weather but as long as my car gets done before the cruise that's all that matters lol
Tyler
Old 04-08-2014   #16
dsmreck
dsmreck's Avatar
Drives: 98 gsx
Just make sure you use that black 3m rust encapsulatir or whatever it's called. I will let u know for sure what it's called later when I can look at the can. The worst is hand sanding that bay good enough for paint. Use 400 grit wet/dry paper and that will be plenty good
Old 04-08-2014   #17
bigboostingst
bigboostingst's Avatar
Drives: AWD Spyder
Yeah the sanding is not fun... Luckly mine didn't have any rust but it definitely was not a one day job. I used POR15 on the seams, it's expensive but has excellent reviews:
Old 04-08-2014   #18
dsmDolney
dsmDolney's Avatar
Drives: Racecars
will look into that por15 stuff
dsmreck what paint color did you also use on your bay when you repained it it looks great and matches the body color well
Tyler
Old 04-13-2014   #19
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Update i got a t it tonight and made some progress got what i needed cut out of the tower. I also picked up some of that por 15 stuff and it seems to work great to get to the little rust i cant get to. Just have to cut out the peice out of the good tower and weld it in.
Tyler
Old 04-13-2014   #20
dsmreck
dsmreck's Avatar
Drives: 98 gsx
yes por15 is what i used i believe. I will check on that color code again for you but dupont is an excellent brand with great color match
