Old 07-19-2011   #1
b00sted_spyder
Anyone good with broken bolt removal?
My lower control arm bolt snapped when I tried removed the control arm. It's the end that connects to the front subframe. I do not want to attempt the job to remove it because I have very little experience and do not have the right tools. I'm willing to pay someone to come over and remove it. If you can help, shoot me a PM. Thanks!
Old 07-19-2011   #2
mondale
Drives: 1g dsm
Re: Anyone good with broken bolt removal?
Could you post a picture for us of what the broken bolt looks like? Clean break, how much is sticking out, etc.
mondale is offline   Reply With Quote
Old 07-19-2011   #3
b00sted_spyder
I'll try to get picture tomorrow.
Old 07-19-2011   #4
Drill drill drill! That's pretty much it. I suck at these, sorry man
Old 07-19-2011   #5
::Insert picture of Sarah Palin naked spread eagle with the caption "Drill Baby Drill"::
Old 07-20-2011   #6
stikx
Mr -
sort of off topic but, what if you strip the threads in the subframe?
Old 07-20-2011   #7
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Tap that ass
Old 07-20-2011   #8
bertrenolds5
bertrenolds5's Avatar
Drives: 91 eagle talon GST
Your pretty much fuk'd, that's why you have to hit everything with penetrating oil and hit it a few times and if that doesen't work hit it with a torch for a few minutes. I would say use a small drill bit and try to cut the bolt out without hitting the threads, worst case senario you have to put a nut on the end of the bolt, but it sucks to be your right now. Are you keeping the control arm? You could sawsall the bolt by the bushging and get the arm off or cut the arm and get it off and then work the stub out.
I'm gonna go with the sarah palin spread eagle and say drill it out and use a helicoil or nut.
Old 07-21-2011   #9
cmspaz
Walls need hugs too
cmspaz's Avatar
^ And of all of that, cutting the arm is still the only SURE way to get it out.
Originally Posted by Trogdor
Old 07-21-2011   #10
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Another trick if any of the bolt is exposed is to weld a nut on the end of it.
The heat from welding helps free up the stuck bolt and you have a nice head on it afterwards to remove it
Old 07-21-2011   #11
b00sted_spyder
Sorry I've been way to busy to be able to get a picture. The lower control arm has 2 bolts connected to the subframe. 1 of them broke and I was able to take off the other bolt. But the arm slid right off so now I can see the broken bolt stuck in the subframe. It has about half an inch I'd say sticking out. The head of the bolt just broke off.
Old 07-21-2011   #12
iceminion
iceminion's Avatar
Get someone with a welder, weld a huge nut on it, make sure the heat penetrates into up into the threads.
Removal - work the bolt in and out, slowly. It will come out.
If you have a 220 outlet I or someone else could bring a welder to you.
Again, pictures would help
building a 3000GT AWD Turbo.
Old 07-24-2011   #13
bertrenolds5
Just get a vice grip and heat the bolt up at the threads with a butane torch till it starts smoking and turn it out then.
Old 07-24-2011   #14
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
I believe I had this exact issue a year ago on my old Talon I sold to CornFed 2.4.
I ended up buying a couple different drill bits, drill it out in stages. Then chased/tapped the threads and was able to use a new bolt from mitsu. Got lucky.
Old 07-26-2011   #15
b00sted_spyder
Finally got a hold of a camera. Here's how it looks like.
Old 07-26-2011   #16
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Torch and a stud remover or Vice grips. Or weld a nut on that batch
