Old 07-13-2011   #1
Chim55117
Drives: 2007 BMW 335i Coupe
Garage Cleanout! Evo III 16G, ACT 2600, EPROM ECU, and More!
I'm trying to clean out my garage this summer, so this stuff has to go!
2G Steering Wheel
The airbag section is light grey and has the Eagle emblem on it, the steering wheel portion is black. - $10
2G Exhaust Manifold
Stock exhaust manifold off my Eclipse, no cracks or anything of the sort in any of the runners - $50
Ported 2G O2 Housing
Had this O2 housing ported by Elvis at Side by Side Performance last year. Worked great with my EVO 3 16G setup. - $50
Stock 2G O2 Housing
Stock O2 housing off a 2G, a great upgrade for VR-4 and 1G owners. - $30
VR Speed Factory J-Pipe
Came off my VR Speed Factory 2G FMIC kit, I stopped using it when I upgraded to my SCM 5031. Aluminum material and polished finish. - $30
Stock 6-Bolt Flywheel
Stock flywheel off a 1G. Could use a resurfacing before seeing use again. - $40
AutoMeter 0-30PSI Phantom Boost Gauge
Not really much to say here, works as it should, in good condition - $15
1G Big Brake Kit
This is the big brake kit of the 1G, which comes with dual piston calipers. - $60
Stewart Warner 52MM Boost Gauge 0-40PSI
Works great, came off a car that we parted out, I have no use for it since I have a ProSport. - $30
SOLD
Blown EVO III 16G
Gray 2G Gauge Pod Pillar
ACT 2600 6 Puck Sprung
Greddy 60MM EGT Gauge
2G T-25
Setrab Oil Cooler w/AN Lines
EVO III Exhaust Manifold
1G AWD AGX Adjustable Struts Front and Rear
VR4/1G EPROM ECU
Shoot me a PM regarding any parts inquiries and I will get back to you as soon as possible. Thanks!
- Stephen
"We are what we repeatedly do. Excellence then is not an act but a habit." — Aristotle
Old 07-18-2011   #2
Chim55117
Re: Garage Cleanout! Evo III 16G, ACT 2600, EPROM ECU, and More!
Sold some parts! Bump!
Old 07-25-2011   #3
Chim55117
Updated with sold items. Bump.
Old 07-26-2011   #4
Swanny
Swanny's Avatar
Drives: 2G Talon
Got the boost gauge still? Can u plz pm me if number
Swanny is offline   Reply With Quote
Old 07-31-2011   #5
Chim55117
Bumpity.
Old 08-12-2011   #6
Chim55117
Bump.
Old 08-12-2011   #7
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Pic of j pipe? Does it follow a stock gvr4 route or does it point down for a short route?
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 08-12-2011   #8
Chim55117
It points down for a short route. Not the same direction as the stock GVR-4.
