Old 09-17-2011   #1
after 10 years its coming back to life
What's going in it
Engine ect
95 pistons on 1g rods
Arp head,main,rod studs and bolts
Rebuilt 1g head light port job
Bc springs
Fp2 cams
Evo 3 turbo off my evo 3
Evo 3 manifold
Tial 38 gate and o2 housing
Bolt on BR afpr
Evo 8 injetors for now
Wally 255
Act fly
Act 2600 or 2900 have both
Sbr fmic off brad's old 2g
B&m oil cooler with push lock line
1g fluidine raditor that was in my 1g and the evo1 swap
Out and in
2gb talon front bumper will get modded to work with 97+ eclipse head lights
2ga talon rear bumper and tails
2ga talon side skirts and door caps
Evo 3 front recaro
That is about it for right now. Trying to sell parts from the 2 parts cars to get the rest I need to get it going
the really old pics of the car
back in 99/00 when colored wire loom was in. also had a wings west front bumper and blitz sides and rear bumper on it then
Then frenched in a 3g eclipse alum gas door on the car
also found the rare edm tails,edm mirrors for the car (have sold them now )
this is how it sat for almost 10 years now all apart no engine in it and every thing stripped out and parts where sold from it
Old 09-17-2011   #2
Re: after 10 years its coming back to life
now it has been sitting in the drive was for a year since I was trying to sell it off. that is when I sold the mirrors,tails,jamex front seats. It looks like this for the most part right now
the awd sub frame
Old 09-17-2011   #3
Any last week I bought 2 parts car to get it back on the road
95 talon tsi fwd auto. It was a rusted out pile of crap and had a rod through the block. This is what I took out of it for my self. A/C,Power steering,alt,e-prom ecu,rear bumper,side skirts with door caps,tails.
Also last week I bought a 97 awd spyder rolling shell. It came with a ton of parts and a 10pt chromoly cage that I sold already. What I took from the car. Black top,b&m short shifter,aem wide band,auto meter oil press,piller pod,twin projector head lights.
had to use the rims off my evo 3 to go get it and bring it home.
got the talon rear end swap done
gutted the inside of the car
then swapped the tops took my tan one off for the black top
My 60.00 craigs list find 2gb talon bumper
also picked up a few parts from Brad. fp2 cams,sbr fmic kit,black mirrors,stock amp,act fly,hawk front pads,tial 38mm o2 housing
my recycled radiator. was in my 1g talon then was in my evo 1 before I sold the shell now it is going in the spyder
Old 09-17-2011   #4
the 95 talon parts car ready to go to scrap. It was a rusty pile of crap.
drivers side rocker panel front to back ^
Old 09-17-2011   #5
going to put in my evo 3 recaros in it. still need a down pipe back. also want to get black rear seat,door panels. grey home link visors,pass piller and the plastic up by the top locks
Old 09-17-2011   #6
Looks good, big improvement on the stockish body parts from the last time I saw it.
Old 09-17-2011   #7
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
Looking good mark! Can't wait to see it on the road!
Old 09-17-2011   #8
Woooo! Keep going man!
Old 09-17-2011   #9
cmspaz
Walls need hugs too
cmspaz's Avatar
Awesome! Keep up the good work!
And you found a Talon more rusty than mine was!
Originally Posted by Trogdor
Old 09-17-2011   #10
Yes I did did not look that bad till I took the skirts off and rust hit hit the drive way. When I jacked it up and put it on stand the first time the stands went through the floor lol.
Old 09-17-2011   #11
Awesome update!
You just have way too many cool cars.
Old 09-18-2011   #12
Woot! It's about time this thing is getting worked on. For as long as I've known you it has been just a pile of parts. haha
Old 09-18-2011   #13
That it has. It has been way to long and getting it running I will have a car to drive if the hatch get sold some time
Old 09-18-2011   #14
What I did on a boring sat. At work. Blasted,coated and backed the o2 housing
Old 09-18-2011   #15
Very nice, I am excited to see how this progresses!
Old 09-19-2011   #16
95talonracer
95talonracer's Avatar
Hmm why not just use that other AWD spyder you got. It looked like it needed nothing.
Amsoil Dealer
Old 09-19-2011   #17
Salaved car
Awd swap was not the greatest
Drivers qt. Panel was fixed and full of bondo and paint was falling off
It was just a parts car any way all I wanted was the black top for my car
My car has a lot less miles and no rust on it
Dash harness was cut up.
Old 10-06-2011   #18
been working on it the last 2 days. It is getting there.
got the fmic put on and started to put the a/c system back in the car
also took out all the abs wiring out of the engine bay harness and put it back in the car. Also did a mini tuck with it. I used the 3 holes that were in the frame rail and make 3 brackets to bolt the fuse box in the wheel wheel.
fuse box bolted into its new home
I drilled out the spot welds on the stock lower radiator brackets and made some new ones and welded them in so I could use my 1g fludine radiator in the car
Old 10-06-2011   #19
worked on fixing the new top since arms were broken and bushing were missing. the install on the frame was messed up. took a few hours to get it to work like it should now it folds down and up just great now.
replaced the floating arms with the ones that were in my top frame. also had to redo the elstac straps so it would pull the arm back when the top folds down.
the arms that were in the car they were broken. the floating bow arms were gone
got the side skirts all on the car now
also got the front bumper cut and put on for the first fitment. I have part of a 2gb eclipse front bumper so I can fill the gaps so I can run the 2gb eclipse head lights
Old 10-06-2011   #20
cmspaz
Walls need hugs too
cmspaz's Avatar
Very nice progress sir. I thought about calling you yesterday to see if you were working on stuff... I guess I should have!
