Old 09-24-2013   #1
Fran05
Drives: DSM
Eibach adjustable coilovers + springs
I have a set of Eibach Ground Control adjustable coilovers with springs. Come with everything needed to install. Best bang for your buck!
$120 shipped obo
Old 09-25-2013   #2
x-pride
x-pride's Avatar
Re: Eibach adjustable coilovers + springs
Would these work on 1G, 2G, FWD and AWD?
Old 09-25-2013   #3
Archertsi
Archertsi's Avatar
Drives: 1995 talon tsi
1g only as they have a larger shaft since they are a strut car.
Awd/fwd shouldn't matter as they are adjustable height. Not sure what ground controls website says though.
@BloodSweatMotorwerks
Old 09-25-2013   #4
dsmghost
dsmghost's Avatar
Drives: 1gb Talon TSi AWD
AWD/FWD does matter when it comes to the actual struts. Also fwd has lower ride height.
Old 09-26-2013   #5
The only thing that would matter is if the strut body had a different diameter in the back, fronts are the same from FWD to AWD. And I think the bodies are the same diameter so it shouldn't make a difference.
FWD has a lower ride height? And why would that matter with these?
Old 09-26-2013   #6
dsmghost
dsmghost's Avatar
QUOTE=Goat Blower;436458]The only thing that would matter is if the strut body had a different diameter in the back, fronts are the same from FWD to AWD. And I think the bodies are the same diameter so it shouldn't make a difference.
FWD has a lower ride height? And why would that matter with these?[/QUOTE]
Yes. It wouldn't matter with these because they don't include the strut bodies, I thought they did at first.
Fwd rear struts won't bolt up to an awd car, the lower mounts are different. My friend accidentally bought fwd complete coil overs for his awd. After the install his ride hieght was way to low and there was no more room for adjustment to raise his ride hieght. He also had to ghetto rig the rears to even bolt up at all.
Old 09-26-2013   #8
I know the lower mounts are different, but that has nothing to do with collars, they simply slide over the shock and rest on a snap ring or the cut down original mount for the regular coil. The rear coils are about the same size as the coilover coils.
And the FWD's are not lower, the lower mount in the rear is different, possibly lower than the AWD mount. If I were your buddy, I would've sent back those coilovers he bought. I don't think I'd want anything "ghetto rigged" on my suspension.
Old 09-26-2013   #9
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
I wonder if this'd do the trick for the Colt's suspension...
Old 09-26-2013   #10
dsmghost
dsmghost's Avatar
Yup, thanks!
Old 09-27-2013   #11
Archertsi
Archertsi's Avatar
Originally Posted by blackrosenova400 View Post
Id take em if I knew they would work on my Awd for sure
They were in Fran's awd so no issue there
