Old 10-26-2013   #1
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Pistons & Rod combo or piston's
Hey Style,
Im in need of some new or used pistons in good condition with fresh rings or no rings does not matter. I am looking for stock compression numbers. I have a Stock 6Bolt 4G63T That has been bored out to .20 which directly reflects on the piston diameter im in need of. Please let me know what you have. If you dont have a set but know of a good place to perhaps purchase some other then the dealer or expensive after market set's please feel free to share. I am in need of just one or a set just to get the vehicle moving again.
Thank you,
Old 10-26-2013   #2
twisted954
Possible Head Trauma
twisted954's Avatar
Drives: after suspension
Re: Pistons & Rod combo or piston's
Realistically, you should bore your block out to MATCH the pistons you are using...if this is what you are doing to bore to .040 then there is a set of wiseco pistons and eagle rods for 250.00 for sale by twitch in the for sale section.
Faster than pushing...
twisted954 is offline   Reply With Quote
Old 10-27-2013   #3
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Those are sold...
Originally Posted by shoutbox
Old 10-26-2013   #4
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
I dont think i quite understand your point? Why cant i just replace the unit in my bore with a replica bore size with no damage to my block? Is a Bottle hone before install to rough up the surface not good enough? Is that what you are referring to?
Old 10-26-2013   #5
I have a stock set of big rods and pistons I was going to build a stock motor but well I said F it.
$50 and they are yours.
Old 10-26-2013   #6
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
What about the size aaron?
Old 10-26-2013   #7
oh you need .020 over?
I think they are just regular old stockers. You can try them out and let me know if they work.
Old 10-26-2013   #8
93gtpeater
Drives: cbr 1000rr repsol
You could just run .20 over rings. I do this all the time on my sleds. I know it sounds crazy and dumb but a lot of people do it.
Old 10-27-2013   #9
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
That sounds retarded... I've never heard of anyone doing this on a 4g63, piston slap would be ridiculous!
Alpha, I have 3 that are in very good shape, pretty sure they are like an "OE" replacement but are .020 over. If they could be of any use to you to make a good set out of the originals. Let me know. They were in a block that a valve came loose in one of the cylinders and trashed one piston. They are on 6 bolt big rods. I can get pictures tomorrow night or monday.
Old 10-27-2013   #10
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Yeah no offense or disrespect, but thats all sorts of Ghetto...that would be a sure shot gamble you dont want to take. Not saying it wont work might just be a little to far from my goal.
As far as the 3 pistons go, let me check with goat blower i like the fact he has a complete set you know that are ready to drop in since i have a set of bearings. If for what ever reason they dont work ill be coming to see you !
Old 10-27-2013   #11
I've got a set of new OEM .020" over 1G pistons and rings mounted on 6-bolt rods. A set of rod bearings away from dropping in. $100 cash firm.
Old 10-27-2013   #12
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Steve you will be receiving an incoming Text within the next few hours. Thank you guys for all the quick responses!
Old 10-27-2013   #13
93gtpeater
I was pulling your chain. Haha. Make sure you check your bore size before buying anything.
Old 10-27-2013   #14
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
-.- what do you think this is MNHONDA's! Jk lol
Old 10-28-2013   #15
dsmreck
dsmreck's Avatar
Drives: 98 gsx
ive got a set of 1g big rods with 2g pistons and new rings in box. pm me if you want them. i have pics on my for sale add or i can text them.
the reason you want pistons b4 you bore is each piston may have a variance. so 20 over what? stock bore or where it was or to a .20 over piston. you may end up with a .20 over piston that has hugr piston to wall because not all things are perfect.
Old 10-28-2013   #16
I can't quite understand what you're getting at here, but .020" over means beyond the stock bore, on these engines, and every other one I've ever heard of. If you want to get technical, "import" motors such as these go by mm instead of inches, so it's actually .50 mm over. Same thing though.
Every time I've had machine work done, my machinist measures all four pistons, takes the largest one, and adds the appropriate PtW clearance for all four holes based on that. PtW clearance is based on the piston material, or manufacturers specs for aftermarket, and I used to go even a little looser than that back in the day. Boring each hole to exactly the same PtW clearance for each individual piston is way overkill.
Trust me, the machine work we have done for these is generally better than what the factory ever did, and those engines lasted 150-200k miles and have withstood 500+ horsepower. Having a couple ten thousandths variance in PtW clearance is the last thing I'd worry about in a rebuild.
Old 10-28-2013   #17
He bought the motor from me, they were new OE re placement .020 over pistons. We did the bore/hone at my work. I think we set ptw to .0025"-.003".
Old 10-28-2013   #18
dsmreck
dsmreck's Avatar
Drives: 98 gsx
there ya go. lucky you have someone to give you that answer. again if you have the money 1g big rods 2g npr pistons new arp bolts new rings..
Old 10-29-2013   #19
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Best engine ever purchased! Solid Sucker...its a shame i damaged it by making a careless mistake. Either way thanks for chimming in John, and well be in touch soon!
Old 10-28-2013   #20
dsmreck
dsmreck's Avatar
Drives: 98 gsx
ok but what if its too tight? ptw is deff important when doing a build. to loose it will slap and wear early and too tight boom with the right amount of heat and stress. Not saying i'm a no it all just saying no way are all pistons the exact same was all and I feel that ptw should reflect the power/boost you plan on putting down. Maybe i'm completely wrong but i will scrutinize my ptw on my builds.
