Old 01-24-2014   #1
mark4g63t
mark4g63t's Avatar
Drives: 95 Talon TSI
AWD Swap Questions
Alright so I have a few questions. First is are there holes for the rear gas tank straps or do I have to drill my own then stick a bolt through it?
Second is do I just remove the rear subframe bolts and put the awd (longer) ones in and if so can I do the same for the front? Or how do the fronts go? I know they have to be moved farther forward. Can I just cut down through the back seat like I did to remove them from the donor car? Just confused on how the fronts go.
Ill post more/ pics and I look more into it.
Thanks, Mark
BW8776, e-85
Old 01-24-2014   #2
mark4g63t
mark4g63t's Avatar
Re: AWD Swap Questions
http://www.vfaq.com/proj-pics/2G_FWD_AWD/SAWDC_006.jpg
If this helps
BW8776, e-85
Old 01-24-2014   #3
mark4g63t
mark4g63t's Avatar
This where the front bolt for the rear subframe goes?
ID:	14141   Click image for larger version
BW8776, e-85
Old 01-25-2014   #4
mark4g63t
mark4g63t's Avatar
Nevermind, got it all figured out.
Almost done!
BW8776, e-85
