Old 07-14-2014   #1
Scheides' Epic Mitsu Garage Sale - DSM, Evo, EvoX parts
Cleaning out the garage!
NO REASONABLE OFFER REFUSED!
Combo offers welcomed.
Can ship if need be but I would prefer to just meet-up/deliver.
Txt me: 612.eight-five-ohhhhhh.1407
PM: scheides
email: chris-at-snowsecurity.com
Evo Front Windshield Wiper Cowl $10.00
Evo ebay 3" downpipe $40.00
Evo OEM Exhaust, no cat, 8k miles $100.00
Evo GSR Stock Suspension, missing one top hat $125.00
Evo GSR Front Shocks $30.00
Evo 7-bolt front case/oil pump/used $40.00
Evo Valvesprings (evo9--no retainers) $30.00
Evo Evo9 cams $40.00
Evo Infinity Amp + Deck $20.00
Evo Stereo Deck $10.00
Evo Front Passenger Airbag $50.00
Evo Rearviewmirror $10.00
Evo ACT Clutch (used) $25.00
Evo Flywheel $25.00
Evo ACT Throw out Bearing $5.00
Evo Airbox - bottom $5.00
Evo OEM intake $5.00
Evo Front Right Knuckle, ABS Sensor $50.00
Evo Rear Right Knuckle, wheel bearing, ABS Sensor $50.00
Evo Right Rear Lower Control Arm $30.00
Evo MR Coilsprings $30.00
Evo Front Wheel Bearing (good) $50.00
Evo SSL Plastics (per piece, let me know what you need!) $5.00
Evo Center counsole $35.00
Evo Exhaust manifold heat shield $10.00
Evo Window Motors + tracks (each) $15.00
Evo ACD Assembly - bad $10.00
Evo Balance shaft (set) $15.00
Evo Crank pulley $40.00
Evo cam gear $10.00
Evo Idler, Tensioner, Water pump pulley set $30.00
Evo crank pulley $15.00
Evo crank trigger plate $10.00
Evo timing tensioner $10.00
1G DSM 23-spline t-case $80.00
EvoX Flywheel $25.00
EvoX Front Rotors (used) $30.00
2G DSM Roll stop inserts $5.00
2G DSM Mint! Radiator brackets $10.00
2G DSM Throttle Body Elbow $10.00
3/S OEM Fuel pump $10.00
2G DSM Stock Fuel Rail $10.00
2G DSM Cylinder Head (clean--can be used for core) $75.00
2G DSM Battery Tray Plastic $5.00
Old 07-14-2014   #2
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Re: Scheides' Epic Mitsu Garage Sale - DSM, Evo, EvoX parts
Do the Evo valve Springs have retainers? Or is it just the springs
11.35 @ 120mph
Old 07-14-2014   #3
Just springs, there are a lot of Evo guys that do basic upgraded beehives and re-use their stockers. That is the case here
Old 07-14-2014   #5
First post is missing some pics, will fix it.
Old 07-14-2014   #6
b00sted_spyder
I see wheels pictured but are not on the list. Are they for sale? 2g cylinder head, does it come with all of the original cam caps?
Old 07-14-2014   #7
Evo8 Enkei's are winter wheels, 1 bad tire 3 worn snow tires. Painted black. $300.
2G Head comes with all cam caps.
Old 07-14-2014   #8
Any idea if that master cylinder will bolt up to a 1G? I'm guessing it has a bigger piston for 4-pot brakes.
Is that other thing a power steering reservoir? Hmm.
Old 07-14-2014   #9
b00sted_spyder
What about the 1gb 5 spoke semi polished? Do you have all 4 or just the 2 pictured?
Old 07-14-2014   #10
Just the 2 1g rims
Old 07-14-2014   #11
The master will bolt up to. 1g. You will need a 2g or evo clutch master cap that is on the clutch master it self. so you can run the clutch hose from the brake master to the clutch master.
Old 07-14-2014   #12
What mark said
The other thing is an ACD pump. I see where you're going though...I'm lookin' and I'm likin'!!
Just 2, one is polished the other is a little dull still. You're welcome to come check them out!
Old 07-16-2014   #13
What's that, you need some evoX pistons? I have 3x JE pistons in great shape. 1 is toast. These have about 20k miles on them, join with a new one from JE and go do work!
Cyl 1 ate a spark plug, compresson was fine but rings/cyl wall was damaged.
Again, make me a reasonable offer.
Old 07-20-2014   #14
Bump! I forgot to add the 3" ebay downpipe to the list, but you can see it in the pics. $40.
Old 07-20-2014   #15
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
Are these IX or X stockers?
Old 07-21-2014   #16
Those are out of the IX--rods are iffy but the pistons are good to go for any 4G63 build Make me an offer.
Old 07-24-2014   #18
You are the second to raise your hand for it, want to swing by and grab it or meet up? Give me a ring/txt and we can hook up.
Old 07-24-2014   #19
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Trade evo 8 enkei wheels for a wh1c turbo freshly rebuilt ? If they are still avaliable
Tyler
2011 Subaru Sti 11.0 @135mph
Old 07-24-2014   #20
Evo wheels are gone, sorry, meant to post up they just left the other day.
What on earth is a wh1c turbo? I'm thinking no thank you
