Old 08-26-2014   #1
Capinoy123
Capinoy123's Avatar
Drives: A paint faded Red/pink/black 90 eclipse. Collector Plates!
Hesitation WOT
So This year my car does not want to run under WOT. Built 2.0 liter BC 280 cams, ECM Link V2. (I'll try to take a log of my WOT tonight on my way home from class.) Bosch 044 Fuel pump -8 fuel feed, -6 return, aeromotive fuel pressure regulator. 1650 blue maxx injectors. Magnus Intake manifold 3" Gm maf so on and so forth. Just trying to get ideas. I use to run 25 PSI all day long but it starts to hesitate as soon as it hits full boost or shortly after. So i thought ignition issues? So i turn the boost as low as it would go. 12 PSI and same thing still hesitates under WOT. I'm running about 11.0-12.0 A/F at WOT. Any suggestions would help thanks!
Best E.T 10.5 @ 137 on 30 psi, E-85 and street tires! (never dyno'd)
Capinoy123 is offline   Reply With Quote
Old 08-26-2014   #2
Re: Hesitation WOT
Did you try new plugs? 12psi is pretty low to have spark blowout though.
Old 08-26-2014   #3
Capinoy123
Capinoy123's Avatar
Re: Hesitation WOT
Yup! First thing i tried. Still the same result! BPR7ES! I have a coil on plug setup too FYI.
Old 08-26-2014   #4
Re: Hesitation WOT
Fuel issue? old gas? filter?
Old 08-27-2014   #5
dsmreck
dsmreck's Avatar
Drives: 98 gsx
Re: Hesitation WOT
Bad coil pack? Try running stock coil pack and plug wires. Fwiw 11 afr on e85 seems pretty rich. I wouldn't rule out that it is too rich as that will give you issues. Any knock?
Old 08-27-2014   #6
Re: Hesitation WOT
Post a log!
Old 08-27-2014   #7
Capinoy123
Capinoy123's Avatar
Re: Hesitation WOT
What is a good a/f ratio for e-85 at WOT? I will definitely try my stock coil pack and plugs this weekend hopefully! Also maybe get a WOT log! I will also look into my fuel system..
Old 08-28-2014   #8
dsmreck
dsmreck's Avatar
Drives: 98 gsx
Re: Hesitation WOT
11.8-12.0 is safe IMO
