Old 12-03-2004   #1
TSISLEEPA
Guest
Tournaments Won: 6
Posts: n/a
Please help! RPM won't go over 2200.
Hey guys and gals. i just finished rebuilding the bottom end of my motor and removing the balancer shafts. when i put the motor back in the car it wont run over 2200 rpms and it runs really rough at idle. i have tried almost everything i can think of. i ran mmcd and it said i had a bad mas so i replaced it. Nothing changed! If you guys know of anything that would cause this please help!
This is what i have into my car.
TMO EPROM ECU
FMIC
Apexi SAFC
2g MAS
balancer shaft block off kit
RC 550 injectors
walbro fuel pump
boost controller
AEM true time cam gears
Je pistons and rings and bearings
egr block out plate
ACT clutch
WEB cams street grind
head is ported polished 5 angle grind decked and dipped
and lots of other stuff i cant think of right now
PLEASE HELP IM STUMPED!!!!!!!!!
Thanks
MATT
