Old 12-05-2004   #1
santa
Boost Spike
santa's Avatar
What to go with over 600hp?
I'm planning on going big this year ?(summer 05) when I get back from school. I'm thinking about going with the eagle rods and wisco piston's? but I was wondering if i should go better than that set up? I am also looking into going with the 2.4 de-stroked to the 2.14 and reving to about 10,000 rpm. I hear that qpr is currently building a motor for someone. I was planning on waiting to make my decision based on the out come of that motor. I will also be building this motor myself. I'm just wondering what people have run, and also what people's opinion's are on a built motor. I will also be running a built tranny of course and also a twin disk clutch of some sore along with slicks a cage and possibly a wheelie bar... well have to see.
Old 12-05-2004   #2
You can't make 600hp on a 4 cylinder, are you crazy?
Old 12-05-2004   #3
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Honest opinion: Save your money. 600 whp dsms are overrated money pits unless you are going to have alot of funding from an alternate source such as drugs or whoring yourself.
'04 Honda Ricer: stock
Old 12-05-2004   #4
do it kev, i have yet to see a single running 2.17L yet. i'd be they make more power than the 2.0s and 2.4s with a proper setup
Old 12-06-2004   #5
santa
Boost Spike
santa's Avatar
Sorry if I'm sounding like a jackass but I'm just looking for internal opinion's... I will be doing it becasue I love to drag my car... go big or go home man. Thanks Gixxer for the prop's now whats all of your opinion's on internals?? and what motor to go with?
Old 12-06-2004   #6
I think Marco might be running a 2.14l. Eagles will hold 600whp. Will they hold 600whp at 10,000rpms? I don't know. You might want a dogbox tranny, if you plan on being able to shift at 10,000RPMs. You might want to use some Crower or Pauter rods. The cost of engine internals are going to be a small drop in the bucket compared to the rest of the parts need to get a DSM to make power at 10,000RPMS. DSMs are not VTEC Honda's, they don't keep making more and more power as you rev high and higher, they usually flatline not long at spooling up and eventually start falling. With the commonly used parts most 2.0ls start dropping power a little after 8000RPMs. With the 2.4ls it's more like 7000-7500. You should be able to make 600whp with even a 2.0l with a 75lb/min turbo and 35psi.
Old 12-06-2004   #7
why is that? is the vtec lobe have some GIGANTIC life/duration or what??
Old 12-06-2004   #8
Yep. The lift and duration on a stock GSR cam make an HKS 272 seem tiny. The stock Integra Type-R cams make Crower "Race Only" cams for DSMs look wimpy. They also have great cylinder heads with small hi velocity ports.
Old 12-06-2004   #9
TheBlizzard
TheBlizzard's Avatar
Drives: Too Many
I think what Kevin is thinking is that with the 2.14 he is going to be able to stay in gears longer which will be more benificial with FWD. But Shanes right in the fact that you are going to spend a fortune getting the car to actually utilize its high reving capabilities. And the shifting is going to be a big issue unless you have an auto. If you are planning on driving it on the street your not going to want to spend the money for a dogbox either just to kill it in a year driving around town.
CRAIG
Old 12-06-2004   #10
I would go with Crower rods. I am not positive if Crower makes the longer rods that you need though (156mm). I know there are at least 2 companies that make the long rods though. Pauters are awesome, but they are wider than Crowers so you run into more clearance issues with them.
One nice thing about the Eagles, they are the lightest rods I have seen. Less weight is a good thing, especially when spinning that high.
Old 12-06-2004   #11
santa
Boost Spike
santa's Avatar
Thanks for the information. If theres more to add that would be awsome. I do know that reving higher doesnt mean im going to make more power like honda's, Craig did make the valid piont that I do want to rev that high because of FWD, and the traction issues. But like I said I want to see one in action and well see what I decide I may just got with the 2.0 for all I know or possibly the 2.3 stroker. Basically my decision rests on some good hard research. Thanks a lot!!
Old 12-06-2004   #12
I'm sure there's a few running around out there somewhere besides Marco. They look good on paper, more displacement and a rod ratio an Indy car would love. Build it up.
I mentioned building one up to Brent since he's actually got a tranny that could handle the rpms. He didn't seem interested in changing from the 2.0.
Old 12-06-2004   #13
Brent actually hasn't really done any research on the newer configurations. He is having good luck with the 2.0 and wants to stick with it. I told him about the 2.14 and 2.4 stuff last year, but he wasn't too interested. He said he talked to Marco some and Marco sent him a few parts, but he didn't like them too much.
Old 12-06-2004   #14
Speedfreak
Drives: four tires
Please do this in a AWD... Mostly worthless in a FWD. Just buy Shane's car for 25g so he can get a 1/4 of his $ out
Old 12-07-2004   #15
MatriX
NO I will be putting this into my laser... since I already have the car.... I want to be a name in the business as in running some impressive e.t's. I love draggin my car. I will do it all my life if possible... The other reason why I'm going with my FWD.... There really aren't many FWD cars running fast e.t's, granet yes there are a few like 10 or so.... I want to be original... instead of sticking this motor I'm going to be building into a AWD car like "everyone and there mom" No offense AWD cars do rock but, it would be more impressive to me to have a car that runs fast times and can back it up street or strip. Its going to be impressive non-the less. And Brian well run them for sure!! A little friendly comp. never hurt anyone!! Its going to be a blast!
I'll give ya a pm or something soon Mike.
This is kevin btw under My buddies s/n
NHB (No Holds Barred) http://www.fcfighter.com/PICTURES/MI...blk-100x90.jpg
As real as it gets.
MatriX is offline   Reply With Quote
Old 12-06-2004   #16
Raptor
ConArtist
Raptor's Avatar
2.14 is a great design, rod clearance should be less of an issue since the crank used is shorter throw than the one the block is designed for. So Pauters should be no trouble to run. Also, Crower has no issue with selling longer rods and I personally would go that route. As far as Pistons, I am to the point where Wiseco has me a bit pissed off so I have been scouting other sources and have some pretty cool info that I will post after I can prove it. The current 2.14 that we are building is using a knife edged crank, a scraper, windage tray and the pistons that we have been looking at. Looks like a promising setup when done. The tranny and other parts are being built to handle it as well. The head is getting a lot of port work and larger valves, cams matched to the expected powerband and an upgraded ignition and intake as well as exhaust and the perfect turbo. Cam and valve spring selection is a pretty big deal with the RPM range intended. And since you asked about dry sump before, this would be the right app for it. Kevin, if you want more info on the pistons we are looking into, PM me or shoot a call and I will fill you in.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 12-06-2004   #17
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Sound like somebody else is building a powerhouse FWD eh Kevin?
We'll have to get together and brainstorm as your shooting for around the same power level as I am. Maybe we can get a multiple purchase discount on some FWD go-fast parts (twin-plate clutch, wheelie bars, etc.)
We're deffinatly gonna run 'em when they're done
Old 12-06-2004   #18
I won't say who it's for but that monster Mike is talking about building is also a FWD deal.
Old 12-06-2004   #19
Curtis?
I will wave to all you FWD guys as I pass you in my low reving 2.4l street tired AWD in the next lane.
Old 12-08-2004   #20
low reving
want torque?
not me, i want the 2.14. it would be really fun and it's still rare, apparently. i bet no one has done it in a 'quest.
i'm sure a RWD tranny exists that can shift very high and still be street driven. or at least modified to do so. T56 maybe?
