Old 02-26-2005   #1
Heads: 1G 6 Bolt vs. 1G 7 Bolt
Car in question: '92 Laser, 6/4, Stock
I'd like to hear people's opinions about the 1G 6 bolt head versus the 1G 7 bolt head. I've read that the 7 bolt head is slightly better flowing and has better coolant passages, is that correct? I believe Nash is running a 7 bolt head on his car? What all needs to be altered for installation of the 7 bolt head? The reason I'm asking is because from what Jacek and I have come up with, my stem seals are shot due to the good compression (I don't remember the exact #'s) coupled with smoking at idle so therefore I'd like to have my head rebuilt this spring. The head rebuild is going to be nothing more than something comprable to the EngineTecs stage 1: http://www.engintecs.com/html/dsm_heads.html
So, stick with the 6 bolt or search for a 7 bolt?
EDIT- After some searching, I see that I would need to drill out the head stud holes from 11mm to 13mm to accept the 12mm 6 bolt head studs if I chose a 7 bolt head.
Old 02-26-2005   #2
Tsi
Tsi's Avatar
Send a message via MSN to Tsi
Re: Heads: 1G 6 Bolt vs. 1G 7 Bolt
I think you'll find some good info there. I know I did, good tech page.
http://www.roadraceengineering.com/1...waptechtip.htm
2003 Solar Yellow SRT-4 Stage2 w/toys
99 Isuzu Rodeo
Tsi is offline   Reply With Quote
Old 02-26-2005   #3
The only main differences in the 7 bolt is 1mm smaller head studs and better coolant flow. The air flow is the same. All stock 1g heads flow way more than what you are looking for Jakey. Just rebuild the one you have.
Old 02-26-2005   #4
Raptor
ConArtist
Raptor's Avatar
What JET said
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 02-27-2005   #5
john
Business as usual
john's Avatar
I would rebuild yours also. I believe Nash's 7 bolt head is off his old 2g. Even a 2g head can be bolted up without any time consuming work. All you have to do is drill the head to 1/2" and pull the seal out of the end of the intake cam. A 1g thermostat housing even bolts up to a 2g head but not vice versa.
97 Viper GTS
Old 02-27-2005   #6
Please get you facts straight or don't post. Nash's head used to be on his 2g, but it is a 7 bolt 1g head.
Old 02-27-2005   #7
See us Iowa folk ain't all that dumb.
Old 02-28-2005   #8
john
Business as usual
john's Avatar
If you can read, I said I believe. That was not my reason for posting anyhow. I was adding info about the difference between the installation of heads.
97 Viper GTS
