Go Back   MitsuStyle > Tech > The Good Stuff
Old 06-25-2007   #1
A1 H-11 12mm headstud info
In the process of swapping mine in, I thought it would be good to give the details for a 1g install as there is no paper work or spec sheet coming with them. Seems like they are coming from bulk shipments.
I talked personally with A1's tech department concerning proper torque, etc. I was told this specifically;
Use plenty of moly lube on the threads, nuts and washers.
Torque down in stages of 30 ft/lbs,
i.e. 30 ft/lbs, 60 ft/lbs, 90 ft/lbs, then final torque to 105 ft/lbs.
No need to retorque after heat cycles, they are good to go.
As a tip: if you are swapping out ARP's that you may have had to shave the diameter of the washers or nuts down to clear the valve springs, do not re-use them on the A1's. The washers will not slip over the threads. Use the A1 washers, even if you have to take the time to shave them down, no shaving was required for my install. The A1 nuts have a smaller shoulder diameter also, so no shaving was required for my install of them either.
They can be swapped in without having to pull the cylinder head.
Enjoy.
Old 06-25-2007   #2
Re: A1 H-11 12mm headstud info
Nice, so that means you found somewhere that is selling them eh.
Old 06-25-2007   #3
Yes sir I did, THE DEVIL HAD THEM!
Old 06-25-2007   #4
I did this also, they are nice studs if you can afford them/get your hands on a set.
Old 06-25-2007   #5
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Thanks for the Tq specs Mike... Mine did not come with them either. They are some very nice studs. To bad they cost to damn much!
Originally Posted by shoutbox
Old 06-26-2007   #6
Now for the average DSM'er $100.00 ARP's are fine. But if you are wanting to turn up the boost to 30-40psi or even higher, then look into the A1's.
I lifted the head at 34 psi and after doing some research I decided to just take care of the problem for good. But I'm sure that anybody could see this happening to them as described below.
In the bigger scheme of things, they could save you money.
Let's see,
ARP headstuds torqued to moly lube spec $100.00
Cometic HP headgasket $120.00
Total $220.00
Head lifts at 30+psi,
retorque ARPs to moly lube spec or 110 ft/lb w/moly lube as recommended by some people (I don't recommend this)
Total $340.00
Head lifts at 30+psi again,
A1 H-11 headstuds torqued to moly lube spec $375.00
Grand Total $835.00
Head stays down at 30+psi.
Or you could just bite the bullet the first time around
Grand Total $495.00
Which way sounds better? $495.00 or $835.00?
btw, I fell in between the above examples,
Grand Total $715.00
Which way do you think I would have liked better?
Old 07-03-2007   #7
Holy Crap $375 for 10 bolts and nuts. What metal are these made of? Titanium?
What is Moly Lube?
Old 07-03-2007   #8
Moly lube is what you you apply to the "nut" end of the studs when you're installing the head.
Old 07-05-2007   #9
I would think the A-1 studs are made from L19, ARP has it also but does not make head studs for the DSM with it, they make rod bolts etc.
L-19 : http://www.arp-bolts.com/Tech/TechMetals.html
Moly lube to reduce friction : http://www.arp-bolts.com/Tech/Tech.html
Old 07-05-2007   #10
ARP L19 is the same material the A1's are made from, H-11 tool steel.
Old 07-05-2007   #11
They'll make L19 studs if you buy a batch, like 10 sets. I read they charge about 200 for a set of the studs, no nuts or washers.
Old 10-15-2007   #12
http://www.extremepsi.com/store/cust...cat=555&page=1 extremepsi has them for the 6 and 7 bolt in stock.
Old 10-15-2007   #13
95talonracer
95talonracer's Avatar
If you have not blown a head gasket yet but want to switch cant you just swap one in at a time and save an additional $120 off of that huge ending total there? This might be an idea for myself.
Amsoil Dealer
Old 10-16-2007   #14
Yes
