Old 12-09-2003   #1
well all a sudden yesterday, the ol talon decided to start bein a lil :censored: again. Well as of now i really have no idea whats wrong, but ill explain everything i can right now. if its hard to follow, i apologize, but here it goes. OK..
Well i recently put on a used head i got not to long ago. I didn't really get the head tested or anything before i put it on, i just know the car it came off of worked fine. So that was good enough for me for the time being. So i put that head on, and i got my old head refurbished basically and now Napa says my old head is good as new with new seals, and they vacuum tested it and she passed. Well anyway, after we had put on that used head, my compression test results were like 140, 110, 135, 70. BUT the car ran fine, and so i was ok with that because as long as i could get around, i was happy. I don't race the car at all what-so-ever. So i really don't know if its the used head, or the piston rings that is causing the low compression in those 2 cylinders. But my plan was basically to get my other head refurbished (which i already did) and then drop in some 2g pistons/rings at the same time i put that other head back in. so that was the "plan". until yesterday. Now my car is smoking outta the muffler pretty nicely, im gunna take a pic just cuz its pretty insane seeing my car look like it wants to immitate the space shuttle launch. But also, there is oil inside my engine bay. like some lil puddles on top of the tranny. and also u can just smell antifreeze when u open the hood. i think there is some antifreeze kinda leaking too just cuz i can smell it, and there are spots in the engine bay that look wet, and i can't tell if its oil or antifreeze. It's just really annoying right now cuz i can't figure out what the heck is leaking. its only leaking on the passenger side of the engine. and it's not like so wet that id consider it a MAJOR leak, but its still no small leak. and i can't figure out where its coming from. but sumthin has to be leakin internally somewhere to make my exhaust all white. but its also leakin externally from sumwhere cuz u can see stuff in the engine bay. Anyway imma take some pics to show u all what i mean cuz right now it prolly sounds like im insane. But if any of this makes sense to you, then please chime in. I'm wondering if its just that one cylinder with low compression just got way worse and that's what is smoking, or if its the headgasket, or possibly the turbo causing the white smoke. But then i know that my compression test results will be wierd cuz they were just a couple weeks ago, but i also have had the turbo be the cause of horrible smoke 2 times. So i don't wanna count that out. This is just going to be an annoying problem, i can tell already. I'll keep everyone updated on what i do incase anyone comes across this problem in their future.
