Old 08-11-2005   #1
Enes
Enes's Avatar
Fans while turbo timer?
Ok, i left the car runing on turbo timer for about 2 minutes and i watched on dsmlink temp get up to 220-223 fans didn't come on at all!!!!
Anyone know of a way to make sure that the fans continue to be functional once keys are removed?
Eric ???
-E
Old 08-11-2005   #2
Re: Fans while turbo timer?
Don't use a turbo timer?
Old 08-11-2005   #3
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
2 minutes is quite awhile. Usually turbos only need 30 second to a minute of cool down time. You could hook them up to a relay running off the turbo timer if need be.
Originally Posted by shoutbox
Old 08-11-2005   #4
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
Pinball Smash Up Champion!
My fans kick in fine on my 1g while it's timing. Did you use the pre-made wiring harness for the turbo timer or did you splice it in?
Old 08-11-2005   #5
1G fans are not run by the ECU like on the 2G. But, yea, don't turbo time it so long. Cars usually get hotter when they sit and idle.
Old 08-11-2005   #6
Enes
Enes's Avatar
yah, as i figured last night i turned it off and since i was boosting it pretty good i bumped it up from 30 seconds to 2 minutes let it cool off..
i let the laptop log the idle as well and i look back after 1minute 38 seconds and the temp is at 223 ouch...
so i put the key back in and get it down to 196 at idle.
Old 08-11-2005   #7
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Somehow your turbo timer is not powering the accessory wire which gives power to your fans. Either use a relay to energize that wire, or just let your turbo timer do its thing for only 30 seconds.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 08-11-2005   #8
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
I didn't realize the fans were controlled by the ecu in the 2g's and not in the 1g's. That's some useful info. Thanks Shane. (not trying to be sarcastic or anything)
