Old 01-03-2006   #1
TurboDomestics
TurboDomestics's Avatar
Cant shift to 1st or 2nd
I cant shift into 1st or 2nd from inside the car, but I can right on the tranny.
I have a 90 transmission, 90 cables, 90 shifter base, and 90 cable holder bracket (or whatever its called), all in my 93 Talon AWD.
At first I thought it was the shifter cables were bent, so I bought some other 90 shifter cables with the base and bracket, but the cable is still about 1.5 cm too long.
Any ideas as to what could be causing this??
-Charlie
4G63 0, Charlie 3
Old 01-03-2006   #2
CarPsyco84
CarPsyco84's Avatar
Re: Cant shift to 1st or 2nd
1.5cm can be made up by adjusting the length inside the car I think... you could at least try it, that nut looking thing but its like an inch long, with 2 lil nuts at each end, on the shift cable. is adjustable.... You can loosen up the 2 nuts and then spin that big connecting type nut and both sides of the cable either go in or out.... just make sure to leave more than 1 thread in the connector, or it will rip out.... and make you think you broke somthing.....
-When in doubt, Moar RPM.
Old 01-03-2006   #3
TurboDomestics
I tried that, but that thing makes it longer though.
thanks anyways though!
4G63 0, Charlie 3
Old 01-06-2006   #4
KrazyTurbo
KrazyTurbo's Avatar
Do you have the cables properly positioned on the shifter/levers? try www.vfaq.com for ajusting information. You shure the tranny doesnt have a bent shift fork when u got it?
KrazyTurbo is offline   Reply With Quote
Old 01-08-2006   #5
TurboDomestics
Yeah, because it will go into all the gears when you shift, right on the tranny.
Ill check the VFAQ, but im pretty sure ive adjusted everything that can be adjusted.
thanks though!!
4G63 0, Charlie 3
Old 01-08-2006   #6
dumb_ricer
Hates Everything
Drives: Neon
Well, if you are confident that you have adjusted everything to the best of where it can be, then you have other issues. Maybe the cable's got stretched or you screwed something up on the install.
420A > LS1 > All Else
I > All else
Old 01-08-2006   #7
TurboDomestics
Thats what I thought at first too, so I tried putting in 2 different sets of 90 shifters/cables, and I tried a set of 91-94 cables. And I tried a million different combinations of the brackets and cables. None of them worked, Im just going to modify the shifter cables a bit.
Thanks!!
4G63 0, Charlie 3
Old 01-08-2006   #8
x-pride
x-pride's Avatar
Can you shift from inside the car when the egine is off? This is without pushing the clutch in.
Old 01-09-2006   #9
TurboDomestics
not, into first and second.
Its weird.
4G63 0, Charlie 3
