View Poll Results: What car would you choose?
Miata, light mods, nothing real fancy, eventually a race built 1.8 with turbo. 8 22.22%
240sx, and turbo as soon as possible. 5 13.89%
DSM, shoot for 300 AWHP again.. 23 63.89%
Voters: 36. You may not vote on this poll
Old 03-20-2006   #1
TurboDomestics
TurboDomestics's Avatar
dumb car choice poll!
I need to find another car to drive and modify. And it has to be a year round car. Ive limited it to the following 3, but I just cant decide which one Id want. What does Style have to say??
Which would YOU do if you had the choice??
1) NA Miata (90-97) Most likely base model, and probably the 1.6 liter. And then buy a 1.8 liter rebuild it, and turbo eventually, if I think it would need it.
Pros:
-Light and nimble.
-RWD!
-Sexy convertable
Cons:
-A bit on the spendy side, for a college kid, and I dont want to take out a loan. $5-6k
-Convertable in the winter??
2) S13 DOHC 240sx. Rebuild the KA24DE, and then turbo and lsd. Eventually a nice S15 front end swap.
Pros:
-Good handling.
-RWD!
-Sexy car, with lots of potential.
-Relatively cheap, $2-3k
Cons:
-Hard to find a nice one with a manual tranny.
-Not as easy to get horsepower out of as the DSM, and not as light and nimble as the miata.
3) 1g AWD DSM. Ive tried before, and failed before. I have a shell, but it might be sold. I just blew a motor up, and im still not excatly sure what happened or why.
Pros:
-Easy HP.
-AWD!!
Cons:
-DSM reliability.
-Not that good loooking, but will do.
So what would you do?
4G63 0, Charlie 3
Old 03-20-2006   #2
Re: dumb car choice poll!
The Miata will probably be the most reliable choice for you, they are tough little cars and very fun. Nothing wrong with having a convertible in the winter, just make sure you are comfortable enough inside it for everyday use and can put up with the more than normal road noise. Another reason I recomend not a DSM is because you already did that and its fun to try new things.
Old 03-20-2006   #3
TurboDomestics
Did you drive your s2k all winter?
Im a little guy, so I dont think fitment will be an issue. At least I hope not.
thanks for the reply!
4G63 0, Charlie 3
Old 03-20-2006   #4
I store my S2k for the winters only because I don't want it getting all salty, but I know many people across the midwest and Canada that do daily-drive theirs year-round. Winter is no different than summer except you need different tires and the top can't go down. Snow/ice/cold doesn't hurt the top any, they are designed for the elements just like any other production car; just take care while scraping ice from the rear window as to not knick the top (not a concern in the older Miatas with the plastic rear window anyways).
Old 03-20-2006   #5
Emcee gsxtc
Emcee gsxtc's Avatar
Meh, your on a dsm board - what should you expect the answer to be? Year round car? in MN? snow? rwd or rwd or AWD? Go Dsm, pick one of our local shops to help you, so you dont blow things up. Then treat it like a Porsche not an old pickup. That means constant maintenance, no zip ties, no JB weld nor mechanics wire. Don't drive it through fields, ditches, or icy parking lots with curbs. BONUS! You already have parts/ cars laying around so there is less initial investment. Just decide on the setup you want with help from the local shop of your choice. Get the required parts, along with all the usual wear parts replaced: headgasket, timing belt, waterpump, and all the other gaskets that get replace with it.
Congratulations! For equal or less than the price of the new car you have a reliable ~300+hp DSM that can cater to your desires all year long.
Run your car not your mouth!
Pick Two: FAST CHEAP RELIABLE
Old 03-20-2006   #6
JiggahMan
I say get a DSM but shoot for 400 whp.
JiggahMan is offline   Reply With Quote
Old 03-20-2006   #7
Tauni
Mazda-ing
Tauni's Avatar
Drives: 2013 Mazdaspeed3
get a 240. ohhhh the snow banks you'll meet!
Old 03-20-2006   #8
LingLing
AznKraut
LingLing's Avatar
you have to weigh in the factor of aftermarket. since none of the above cars are near 300+whp.
KA24DE:
  • Bore × Stroke: 89.0 × 96.0 mm
  • Max power: 155 hp (115 kW) @ 5600 rpm
  • Max torque: 160 ft·lbf (217 Nm) @ 4400 rpm
  • Valve Configuration: DOHC, 16 valves
  • Compression ratio: 9.2:1
Miata:
The original Miata came with a 1.6 L double overhead cam inline four-cylinder engine, producing 90 kW (120 bhp) and 100 lbft of torque. The engine employs an L-Jetronic fuel injection system and a camshaft angle sensor instead of a distributor.
DSM (1g AWD):
4G63T, Turbocharged 16Valve DOHC, Estimated HP: 195
I'm not sure how the aftermarket scene is for the Miata or the KA24DE. BUT I can imagine that there isn't a whole lot for that engine. I know there's qute a bit more for the SR20DET, but the KA24DE motor is almost obsolete, as the SR20DET is a much stronger and more reliable platform
. If there is, it's probably expensive, like Supra, 350Z, and AE86 parts. Just my .02.... Good luck on your decision though!
Old 03-20-2006   #9
Originally Posted by TurboDomestics
What does MNSC have to say??
Go ask them and find out.
Old 03-20-2006   #10
TurboDomestics
Aahhh shoot. Well I just copy and pasted it fromt there to here. Sorry!
4G63 0, Charlie 3
Old 03-20-2006   #11
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
well so far, it sounds like you've failed with DSMs. If you're like me, you wont settle for them getting the best of you, and try again If you're not like me, say screw it, and get something else. I vote for neither miata nor 240. Miata = butt ugly and goofy looking. 240 = ehhh, what you wanna be a drift superstar? My vote is DSM.
Old 03-20-2006   #12
eclipseGSX108
eclipseGSX108's Avatar
Send a message via AIM to eclipseGSX108
dsm...
but if you were to do the 240sx.. do a sr20 rather then rebuild the KA24
miata... um.. get the new turbo charged ones and maybe you'll get somewhere
eclipseGSX108 is offline   Reply With Quote
Old 03-20-2006   #13
LingLing
AznKraut
LingLing's Avatar
Originally Posted by eclipseGSX108
dsm...
those turbocharged miatas are pretty quick. like 215 to the crank? plus they weight close to nothing.
Old 03-20-2006   #14
The MSM was one of the most fun cars I've ever driven, CVD and I tore it up pretty good in that car. We even took it to the famed Miata-pad. I'm not sure what the used market looks like for them, but about 1 1/2 years ago I saw a dealership closing left-over models out for $19k!
Old 03-20-2006   #15
Shrep
LSE Performance
Shrep's Avatar
Hmmm...go 240 now before the prices go up LOL
Shrep is offline   Reply With Quote
Old 03-20-2006   #16
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
i have a sr20det motor with a blown piston. I'd personally get the 240 (95+) because i've driven my uncle's sr20 powered 240 and it was pretty fun. Winter shouldnt be that bad, i've driven my dad's tundra (rwd only) and it wasnt all that hard, it was more fun
ლ(ಠ益ಠლ)
Old 03-20-2006   #17
CDeutsch
CDeutsch's Avatar
Do a Galant VR4. Ok, I may be biased because I just happen to have one for sale.
If you're driving it in the winter it seems like AWD would be a no brainer. DSM's are reliable if you find the right one and don't go nuts. If you plan on doing major mods on any car you should probably have a backup car or at least a backup plan.
06 Evo IX RS
99 Miata
Old 03-20-2006   #18
Go DSM and follow Emcee gsxtc's advice. Treat it like a Porsche, not an old truck. This is the main problem with dsm's, people don't give them the maintenance they deserve. Evo3 16g + FMIC + Injectors + AFC/DSMLink on a stock motor & you're set. Treat it nice.
Old 03-20-2006   #19
Build a dsm right, and treat it well. If you beat the shit out of any car, it will break.
Old 03-20-2006   #20
pinkys10
pinkys10's Avatar
true but mostly a dsm
WE DUMB....DUMB AS HELL!
pinkys10 is offline   Reply With Quote
