Old 04-28-2006   #1
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
Who has used 1600cc Injectors
I need to upgrade my injectors once again and the fic 1600cc injectors are priced right but I have heard of some driveability issues with using these injectors. Wondering if I should pick these up or maybe spend some more money and buy the 1150cc injectors fic sell. Anyone have any experience with these injectors?
I have a 2.4, pte 3561, DSMLink, Buschur AFPR, supra TT pump. I also plan on running ethanol on the street.
Jim
Old 04-28-2006   #2
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Re: Who has used 1600cc Injectors
Will you even need 1600cc injectors? I would just go with the 1150cc instead. I know Jake (eclipseGST) has 1600cc with DSMlink and they idle fine.
-Colin
Old 04-28-2006   #3
TalonFiero
moonshine power
TalonFiero's Avatar
-Colin
I don't think I will need all of 1600cc but I could see myself possibly maxing out 1000cc-1150cc injectors running ethanol and high boost. I am maxing out my PTE 780cc injectors on ethanol at around 22-23 psi and I would like to run quite a bit more boost. You need 25-30% more fuel when running ethanol compared to race gas. Ecoli has experienced even more than 30% fuel addition when tuning on e85.
Thats right, Jake bought Shane's old 1600cc injectors, good to know he is having decent luck with them.
Old 04-28-2006   #4
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Yep... They run awesome. Global is 72% and deadtime is 450 with PTE 1600's.
Its nice to have larger injectors just for the fact that you'll never have to upgrade again and thats just one less thing holding you up later on. When I ran my car on the dyno, the most airflow I saw before the turbo blew was 51lbs/min and I was at 29% IDC (injector duty cycle)
I have also heard that Chris (v8killa) is using 1600s with DSMlink also and they were running good, not sure if that is true or not, just what I heard when I was buying the injectors.
Originally Posted by shoutbox
Old 04-29-2006   #5
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
haha 51lbs/min at 29%!!! haha that is fucking awesome!
-Colin
Old 04-29-2006   #6
rst95eclipse
There's a guy on another board that is taking out his 1600's and AEM EMS to run DSMLink and 880's just because he hated tuning it. He's running a large turbo that I haven't heard of, but similar to a GT-35R.
Old 04-29-2006   #7
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Many people on the dsmlink forums are running them Jim. Search on there and you will find a big thread with what people have said about them. Most people like them and havn't had much of a problem tuning with them.
7/25/09
Old 05-03-2006   #8
v8klla
v8klla's Avatar
I have had no problems thusfar, however my car idles upwards of 2000 rpms.
It's always nice to have a little extra room up top though, at 87 lbs/min I'm at 75.6% duty cycle
CC
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 05-03-2006   #9
CDeutsch
CDeutsch's Avatar
Is that by choice? Or because of the injectors? My ISC is flakey right now and idles at 1500 rpms. Even that can be annoying in stop and go traffic.
Nice airflow numbers!
06 Evo IX RS
99 Miata
Old 05-03-2006   #10
v8klla
v8klla's Avatar
It has more to do with my cams, and the fact that I don't drive on the street all that often. I could probably get it down into the 1500 range if I wanted. It's also important to note that I do not have an IAC motor any longer and change idle speed by the BIS alone...
Chris
P: 763-545-3800
Old 05-03-2006   #11
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Holy shit, your flowing 87lbs/min... Is this in the GSX and I sure hope thats not what you ran when you put down the 11.3 at RF?
Thats nice to know about the duty cycle. What gas are you using and what size fuel pump?
Old 05-03-2006   #12
v8klla
v8klla's Avatar
Yes that was in the GSX, however these numbers were achieved after I added the Magnus Race Intake Manifold and a Q45 throttle body along with 3.5" intercooler piping. I Didn't have a chance to make a clean run after these additions last season. The 11.3 @ 133.7 pass (note the mph with my stock ass suspension and 18" wheels lol) was flowing around 73 lbs/min...
Hoping to improve on that significantly this season
Chris
P: 763-545-3800
Old 05-04-2006   #13
The lb/min numbers aren't going to be accurate unless you have a 100% stock 2g MAS on the car.
Old 05-04-2006   #14
v8klla
v8klla's Avatar
You are correct I am using a GM MAFT, thus the numbers cannot be 100% relied upon in regards to lbs/min. However, as you may remember we spent many hours on elite's dyno removing and replacing the stock 2G MAS to get the airflow correction as close as possible...
P: 763-545-3800
Old 05-04-2006   #15
TalonFiero
moonshine power
TalonFiero's Avatar
Anyway, I ordered 1600cc injectors from FIC. I appreciate everyone's input and I'll let you guys know how they work out for me.
Jim
Old 03-25-2007   #16
Just thought I'd bring this back from the dead real quick as I just installed my PTE 1600's. I've found mine to idle best right now at 70% Global and 375 deadtime. I've been searching and searching and can't seem to fine an exact number to use as far as deadtime goes on these. Generally I found people running anywhere from 350-400 (and 1 case of someone running FIC1600's @ 180), and anywhere from 65-75% global. The equation from the Link forums was (450/1600) - 1 = ~72%. So that's where I started, but ended up getting my best idle at about 70%.
This is still on 92 pump. I just wanted to get it running somewhat decent on pump, before I start doing full E85 here shortly.
