Old 06-03-2006   #1
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
burning oil :(
My 2g gsx is burning quite a bit of oil. I've swapped turbos hopeing that was the problem, but its still putting out quite of bit of blueish smoke I've done a little research and talked to a few people and I've come to the conclusion that its probably my rings or valve stems. I don't have the money to do this whole project at once, so my questions are...
a) Would I be better off just swapping on a 1g head and replacing all the parts (as to swapping another 2g head)?
b) Can somebody help me find more information on this? I've looked some but I don't know what to type into the search bar.
thanks
-brian
pics or gtfo
Old 06-03-2006   #2
Thor06
11 Seconds to Freedom
Thor06's Avatar
Re: burning oil :(
Valve springs/retainers wont cause you to burn oil, if its not the turbo its either rings or valve stem seals.
Old 06-03-2006   #3
HiImBrian
HiImBrian's Avatar
Re: burning oil :(
Oops! Your right, my mistake.
pics or gtfo
Old 06-03-2006   #4
Thor06
Thor06's Avatar
Re: burning oil :(
Heres my deep thought for the night. Shitty rings can cause you to burn oil correct? Also, shitty rings can attribute to low compression right? I'd do a compression check and if the compression is low, I would assume rings. If not I would assume valve seals. I seem to think its your valve seals. You can get them for cheap as hell so if you pull it, disassemble it, and have someone put the new seals on (you need a special too according to the haynes manual) it should be too bad. However, as long as you have it off, you should get a new head gasket and ARP headstuds and do the timing belt as well. Getting the valves done isnt exactly a bad idea either. Oh while your at it get some cams. See what happened to me when I needed to pull my head for a headgasket?
Old 06-04-2006   #5
santa
Boost Spike
santa's Avatar
Re: burning oil :(
You certainly do not need a special tool to install valve seals. find the right size socket and push them on by holding the socket in hand. Just make sure the seals are square once your done.
My guss is you've got some cracked ring glands, or else a possibly detonated piston.
Old 06-04-2006   #6
HiImBrian
HiImBrian's Avatar
Re: burning oil :(
How would I actually go about finding out what's wrong with it? I'm planing on getting a seperate 1g head and then I'll do all the seals, head gasket, arp headstuds, and cams. I would rather slowly build up a second head and then swap it in when it's all done. Anybody know of any good referances where I can read up on this more? And again, how would I actually go about finding out whats really wrong?
pics or gtfo
Old 06-04-2006   #7
santa
Boost Spike
santa's Avatar
Re: burning oil :(
The only way to find out about your piston's is to pull them out and check them. I'd check the head thats on your car now, once you decide to pull it off. Are you absolutly sure that this turbo that you put on is not bad too? I'm under the impression that it was used?
Old 06-04-2006   #8
HiImBrian
HiImBrian's Avatar
Re: burning oil :(
Yes this is a used turbo, I baught it from swift. I was smoking pretty bad with the turbo before too. There is a tiny bit of shaft play on my current turbo, but from what I understand from swift there is supposed to be a tiny bit where the oil can circulate.
pics or gtfo
Old 06-05-2006   #9
HiImBrian
HiImBrian's Avatar
Re: burning oil :(
Compression results are here: 160:170
pics or gtfo
Old 06-05-2006   #10
santa
Boost Spike
santa's Avatar
Re: burning oil :(
I'd look further into it just to be sure your not burning oil that was left from the last turbo in the exhuast pipes? Also be sure to check that new turbo for any shaft play. I wouldn't just to ripping it apart so fast. Check that stuff over well and get back on here with your result.
Old 06-05-2006   #11
HiImBrian
HiImBrian's Avatar
Re: burning oil :(
Well, put this turbo in about 4 weeks ago and its still smoking pretty bad. One guy came into my work today after I was letting my car idle and cool down and told me my car was on fire! I just had to shake my head at that one. Anyways, I checked my current turbo for shaft play when I put it in and there was very minimal shaft play. But I was told that there should be a small amount of shaft play for the oil to circulate. Is this true?
pics or gtfo
Old 06-05-2006   #12
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
Re: burning oil :(
Every turbo has a little bit of shaft play..that's normal. Hell the PTE dual BB turbo I sold a while back had TONS of play, but after talking to brian at PTE for a good amount of times..he assured that on that turbo, it was normal.
-A. Swift
Old 06-06-2006   #13
Re: burning oil :(
Why are you so convinced its your turbo?
Old 06-06-2006   #14
HiImBrian
HiImBrian's Avatar
Re: burning oil :(
I don't think its my turbo, I'm just replying to what other people said.
Shane: How would I check for gas? Just change my oil and see if there's gas in it? Can you send me a link with more info on "blowby." I'm unfamiliar with that term. Thanks.
-brian
pics or gtfo
Old 06-06-2006   #15
Shane55113
Now 20% less Racist
Shane55113's Avatar
Re: burning oil :(
check your oil for gas when you do an oil change, that would be a good sign that you have blowby.
Old 06-06-2006   #16
Thor06
Thor06's Avatar
Re: burning oil :(
Blowby is when air/fuel mixture passes between the cylinder wall and the piston do to shitty rings.
Old 06-06-2006   #17
Re: burning oil :(
how much oil is burning? i.e. how many miles do you drive and then how much do you have to top it up?
Old 06-06-2006   #18
HiImBrian
HiImBrian's Avatar
Re: burning oil :(
I don't know exactly how much I'm going through, I havn't had to top it off yet. I'm running ams oil 5w 30 and it's been a hair above full for a few weeks now.
Thanks for that url Shane, I'll try taking off the oil cap and feeling for air later today when I'm off work.
-brian
pics or gtfo
Old 06-06-2006   #19
Shane55113
Now 20% less Racist
Shane55113's Avatar
Re: burning oil :(
To check if you have blowby you can either check your oil, it'll look smoky or hazy instead of just dark. And another good sign is when you start up the car and take off the oil cap and hold your hand over the oil cap hole and feel if a lot of air is moving through it, thats an ominous sign. i found something that may help http://www.misterfixit.com/blow-by.htm
Old 06-06-2006   #20
Swifty1638
Swifty1638's Avatar
Re: burning oil :(
It can also be caused by a cracked piston.
-A. Swift
