Old 08-15-2006   #1
Boostin_dreams
Send a message via AIM to Boostin_dreams
Speedo wont work HELP!
Heres the deal my speedo doesnt work i checked all the fuses, and they are all ok, next i replaced the speedo unit on the tranny, and it still doesnt work. So i played around with electrical stuff for a while and between the dark green wire and black(ground) theres was 5v with the car in the on position. Nothing between the light green and black nothing only had voltage between the dk green and black. Then i started the car and put a test light between the dk green and black wire. The idle bogged down to like 400rpms, nothing between all the other wires. ANy suggestions or anyone know what the problem could be?
Boostin_dreams is offline   Reply With Quote
Old 08-20-2006   #2
earthwonder
Re: Speedo wont work HELP!
When my speedometer went out, it was because of my dead alternator. It wouldn't hurt to get your alternator checked, it's usually free at Autozone, Advance Auto, etc.
earthwonder is offline   Reply With Quote
Old 08-21-2006   #3
Boostin_dreams
ANyone know how to test the wiring and/or the actual speedo?
Old 08-30-2006   #4
Do you have a FSM?
Old 08-30-2006   #5
Boostin_dreams
Anyone? well i was talking to a tech at work today and he says i might need a new speedometer anyone have an extra gauge cluster i could borrow to see if thats the problem?
Old 08-31-2006   #6
Boostin_dreams
Fsm?
Old 08-31-2006   #7
Factory service manual
Old 08-31-2006   #8
Boostin_dreams
yea but its not in there
Old 09-14-2006   #9
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Mine wen't out to a bad bit of wiring in my gauge cluster. It also caused some strange cruise control. I think trying a new cluster is a great idea.
Old 09-15-2006   #10
marcell6492002
marcell6492002's Avatar
check your fuse. The speedo is powered by a fuse. If that is not the problem then you have a bad speed sensor. It is on your tranny. If that is cracked, your speedo wont work either.
marcell6492002 is offline   Reply With Quote
