Old 09-04-2006   #1
Redline xfer/rear end fluid
What Redline fluids do you use for the Xfer case? 75w/90? For the rear end? I heard it's a mix of Shockproof (which one) and 75w90. My search didn't work, so I had to ask before I order this stuff.
Old 09-04-2006   #2
Re: Redline xfer/rear end fluid
I use Shockproof in the rear diff, and the ever so popular mix in the tranny/xfer case. That's what RRE always recommended to me so that's what i've ran ever since.
Old 09-04-2006   #3
I run heavy shockproof in rear end and T-case.
Old 09-04-2006   #4
Has anybody seen any bad effects using heavy shockproof in the viscous rear diff?
Old 09-04-2006   #5
75W-90 is the proper fluid for the rear diff. Unless you are a hardcore track star there is no reason to run the Shockproof (this stuff was not designed to be used as a street fluid).
Old 09-04-2006   #6
So just change it a little more often, big deal.
It protects like a 75w250 but is as thick as 75w90. It is supposed to have less fling off of the gears and help prevent gear breakage.
Old 09-04-2006   #7
It is actually a lot thicker than a 75W-90, but it has the fluid friction of a 75W-90.
Old 09-04-2006   #8
http://ricks2k.com/products/le607.php
This is a straight 90W gear oil and dominates all 75W-90 lubes in terms of protection; not for winter use though.
Old 09-05-2006   #9
I run the heavyduty shockproof in both DSMs in the transfers case and rear diff. The transfer case stuff gets changed when it falls over and leaks out during tranny swaps.
Old 09-05-2006   #10
So just 100% shockproof, no mix?
