Old 12-02-2006   #1
Electrical Home Work / Recessed Lighting Specific
Jana and I where talking, and we where looking at things we can start to look at doing on the Townhome to not only increase the value, but give it some additional to stand out among other units that might be for sale around the same time.
Has anyone had an really good expericance with bringing in someone to do this kind of work work, or have they found that doing it themselves was worth the work? If you've hired for it, feel free to suggest someone. I have a bowling team mate I am going to talk to about this as well on Thursday.
We currently have the rough, textured, celing paint and it might even be in out best intrest to change that at the same time.
This would be somethign that would change the complete appearance of the kitchen, dining, and living room area.
Old 12-02-2006   #2
Re: Electrical Home Work / Recessed Lighting Specific
You are going to have to rip the whole ceiling down to do it. In a house with no upstairs it isn't a big deal because you can run the wires for the lights above, but you guys have an upstairs.
Have you guys looked at some of the new track lighting? That would be a lot easier to put in.
Old 12-02-2006   #3
Do it yourself, it's easy! I did the lighting in my kitchen myself, it was not too bad. Consider some under-cabinet lighting as well.
Pick up a basic how-to book @ home depot, some 14-2 wire, and some remodel cans and go to town!
I've also been told to center the lights over the edge of the counter top.
Old 12-02-2006   #4
I haven't been to your place in a while, but if you have any white walls or ceilings, consider paint! It is the best bang for your buck to pump up that resale value!
Old 12-02-2006   #5
We where also thinking of doing some cool drop down lighting over the breakfast bar. Plus we want to do something with out cupboard and light switches for a light change.
Jet, couldn't we just drill holes in locations and run wires in slotted areas around the edges of the dry wall?
Scheides, we will have to get back over to your place to see it again up close. But I remember looking at it a bit, and it looked sweet.
Old 12-02-2006   #6
tim
tim's Avatar
Yes, thats what you do. You can actually get flexible drill bits that are upto a few feet long to drill through studs. It is a pain but that is how it is done. I would suggest finding an electrician for this, it takes experience to be able to do it properly.
Old 12-03-2006   #7
This is one of the most repressive statements ever. I was told once that if I've never buffed a car before, I should never try it because I didn't know how. Gimme a break, the only way to learn is doing it yourself.
For your recessed lighting, it's SO easy, do it all yourself, and only call someone in if you really screw it up bad. everything can be fixed in a home, there are products for everything.
I forgot to mention that if you have questions about code, get a book from home depot about wiring, and current codes. Doing electrical work is nothing to be worried about either, like some people have said, if you aren't sure where power is on, flip the main breaker to "off" and go crazy. just work during daylight hours and get a battery powered work light. 2 people is better than one, even if the other is just standing there reading from the book.
Good luck!
Old 12-03-2006   #8
rst95eclipse
I wasn't being repressive. Read my previous post again. I recommended a professional/licensed company due to the insurance. What if the house caught fire due to these lights being installed improperly? I'm certain that there are something that just cannot everything can be replaced.
Old 12-03-2006   #9
tim
tim's Avatar
Buffing a car is a little different than doing a bunch of rewiring on finished surfaces. If it was new construction or if he had access to the top side I would suggest doing it himself too.
Experience goes a long way when you are doing something like this. I never said to hire a business, but finding someone to do a little sidework would be a good idea.
Old 12-02-2006   #10
I have never seen wire run inside the drywall and probably isn't legal. It is just drywall on the ceiling, so it really isn't a big deal to redo it, especially if you want to get rid of the popcorn ceiling anyway. One of my guys is a master electrician, so I can check with him on Monday.
Tim, you still have to rip holes in the ceiling to get up there with a drill bit!
Old 12-02-2006   #11
tim
tim's Avatar
Yes, you drill the hole where you are going to mount the lights. Then use that hole to feed in the long ass drill bit. I know a guy who is an electrician also and have seen him do it.
Like I said, it is a pain and takes a lot of work to have it done right.
Old 12-02-2006   #12
92EvilTalon
3.1L v6 power...
92EvilTalon's Avatar
Pit Stop Challenge Champion!
Drilling threw studs is not a problem. Code requires you to tie it down like a foot away from the outlet or fixture. But everything else you can run a wire all the wayaround the house. As for lights in the ceiling...its not hard to do. If you don't want to rip the ceiling down to do it just tracklight it. You can get tear drop lights for that table and spot lights for the sink too.
Do you have a light fixture up there already? If so then you can build that tracklighting off of that. You do not have to get a track...they also have wire tracks and other crazy track style lighting. Let me take a photo of my office and you can see the sweet track light I have for it. I love how it looks.
Josh LaCroix
Old 12-02-2006   #13
Yea, you use a long-ass drill bit. I have one, they rock! My house is open above, so it was a little easier in that respect. However, my kitchen had drywall put up over the original lathing/cement (house was built in 1913), so that took the fun straight out of it!
Instead of taking down the whole ceiling as JET suggested, you can just cut holes in key spots for drilling and then patch them afterwards.
Old 12-03-2006   #14
I'll take some pics of our current layout and post them up tomorrow. Would love to just get some ideas and thoughts they we may not already have thought of. Also, big thanks for all the info so far!
Old 12-03-2006   #15
Here's some pics of my mini remodel. Not very good quality pics, sorry!
http://www.scheides.com/gallery/house-work?page=5
If you're gonna do it yourself, be prepaired for the worst:
Old 12-03-2006   #16
Damn scheides, you never told us you were dating Joey Ramone's sister.
Old 12-03-2006   #17
Hah! Anna looked like such a rock star that day I couldn't help but snap a pic of her!
Old 12-03-2006   #18
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
My friend Jesse is a journyman electricion and is taking his masters soon. I think you've met him a few times. He would be willing to do some work for you. running the wires could be easy or hard depending on what type of floor joists you have. If you have a floor truss system it would be pretty easy. TGI's or 2 bys would requier alot of drilling. Can light are very exspensive to have installed. I think the going rate in new contruction is around $100 per can. I know this cause Jesse kept giving me crap when we installed 16 in my basment. Give me a call or shoot me a PM if you want to have him come take a look at it.
11.35 @ 120mph
Old 12-03-2006   #19
The cans usually (maybe not all?) have a junction box on the side too, so they need to be installed from above. I want to do recessed lighting in the kitchen and the g/f wants to do some of the funky track lighting. I can get at everything from the attic, so it would be easy for me.
Old 12-03-2006   #20
carltalon
carltalon's Avatar
The cans usually (maybe not all?) have a junction box on the side too, so they need to be installed from above. .
There are cans made for re modling that can be put in from the bottom side running the wire would be the only hard part placing the cans is easy.
11.35 @ 120mph
