12-08-2006
#1
Another new product, High Rev Valvespring Kit!
We were very tired of waiting for our perferred vendors to get titanium in stock, so we decided to work with a new vendor. With there help we came up with an upgraded valvespring that should easily support 9000rpm and most aftermarket camshafts (except the fp3x and up).
These also come with a Chrome-moly retainer.
$279.00!!!
We do not have them in stock currently, as we haven't placed an inventory order, but they are a week out if we need them.
12-08-2006
#2
Re: Another new product, High Rev Valvespring Kit!
Any idea of the actual spring pressures?
12-08-2006
#3
Unsure resident asshole
Work for those brian crower 280's?
-A. Swift
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
12-18-2006
#4
I would have to see the profile on the 280's. Lift, duration, ramp angles. I haven't tried them yet.
What spring pressures do you want Jet, and at what lift?
12-18-2006
#5
Can you get these for a 95 M3?
12-18-2006
#6
I can look into getting springs for you peter.
What specs are you looking for? Upgrading cams? Just pm me.
12-18-2006
#7
Probably keeping the stock cams, because anything aftermarket is 1500 for a set... But a different chip will let me rev higher, and Im doing lifters anyway.
12-18-2006
#8
Cool. How high are you reving it? Do you have a valve spring compressor?
12-18-2006
#9
Just wondering so people can compare them to Crower's, etc. My Crower's are actually doing ok with the 415's, but I would feel safer with something a tad stiffer.
12-18-2006
#10
I have measured Crower and stock springs for dsms and the Crowers are about 70lbs at an installed hight of 1.57" and a stock spring is 66lbs. Then if you have a .4" lift cam that would be 190lbs of pressure vs stock of ~170lbs at .4" lift. So Crowers are about ~11% stiffer at .4". The LSE spring/retainer combo will work for anyone running a Crower 64415-2 cam size and reving to 9000rpm, then we can size/come up with a dual valve spring kit. Then when Ti becomes available we can sell that also.
12-18-2006
#11
The car revs to 7 with a Dinan chip in it now.. I would get a different chip that will either leave it at 7 or raise it to 7.5.
Either way, I kind of want to replace the stock springs with new ones or nicer ones. The car is getting close to 100k, so I figure if I replace the lifters, why not do the springs in case I decide to mod the car more in the future.
12-18-2006
#12
Hell yeah, about time you introduced yourself into some power.
So thats retainer's & springs for $279?!! Seems like a good deal
12-22-2006
#13
Darn right it is a good deal.
We should have these instock the 1st week of January. Waiting for some custom work to be done on the retainers  .
12-22-2006
#14
Alright, why the chromoly retainer? Are you making it thinner than the stockers?
12-22-2006
#15
Cheaper and more available...the chinese have been buying up all the titanium. Plus the weight difference isn't THAT huge for most applications.
12-22-2006
#16
Chromoly isn't lighter than carbon steel, so I was just wondering why these would be better than the stock retainers?
12-23-2006
#17
Once we get them in, we will weigh them to see the difference.
12-23-2006
#18
Chromoly is stronger so you could take some material off and keep the same strength. A huge weight savings would be a groove going up between the valve and the spring. That material does nothing in there. You could probably save 25% of the weight in there.
02-21-2007
#19
Since it appears that you're selling these now,
http://www.dsmstyle.com/forums/showthread.php?t=14466
do you have any of the weight numbers?
02-21-2007
#20
Originally Posted by Jakey
They weigh the same as stockers  . Our maching only measures in 5 gram increments, so we have to get something that is a little more accurate, and can go down to 1 gram and .1 gram incriments. More info to be posted when we get it.
| Thread Tools |
| Display Modes |
Hybrid Mode
