Old 02-25-2007   #1
Injectors
Well, I have been looking for 1600cc injectors and found these:
http://store.summitracing.com/partde...5&autoview=sku
These are the correct ones, right? Anyone want to go in on a set? $200 for 4.
Old 02-25-2007   #2
Re: Injectors
I'd write them and make 100% sure they are in stock. And ask them twice. Everywhere I tried to buy them from were sold out for an indefinate period of time.
I ended up giving up, and just bought a set from LSE. But if you find out they are in stock, hit me up on AIM, I'd be willing to get another set.
Old 02-25-2007   #3
b00stcreep21
I hate everyone
b00stcreep21's Avatar
Re: Injectors
Also, DSM injectors are peak and hold, those are saturated style injectors
Old 02-25-2007   #4
Re: Injectors
The factory DSM ECU and his AEM EMS are designed to run high impedance saturated injectors. Mitsu just went the cheapo route and threw a resistor box in to allow the use of low impedance injectors. The ECU still runs them like a saturated inj, it doesn't do anything special to truely make use of a peak and hold style pulse.
Those injectors are a weird ohm, but the AEM EMS seems to have a Ford Motorsport 152lb 5ohm injector in the injector wizard.
Old 02-25-2007   #5
Re: Injectors
After researching all of thise awhile back, what I gathered was all these other companies selling 1600cc injectors (PTE, FIC...) they all are using the Ford injectors, and just reselling them under their own name. Matter of fact some of the injectors people are receiving from these companies, there's a ford logo on some of them. There are a couple different companies who make these for ford (Bosch, i forgot the others) which is why you will see some that are different colors (white, red, grey).
From everything I've found, these are basically the same injectors you will get from any other source, and will perfom the same as anything you'd buy from one of the DSM vendors. Slight machining to the injector or the fuel rail may be required though. Not really a big deal though.
Old 02-25-2007   #6
Re: Injectors
Thanks a ton Shane! So I can get these, kill the resistor box and be good to go. Excellent!
Once again, anyone else wanna go in on a set?
Old 02-25-2007   #7
DBMajik
Re: Injectors
For $200 I'll definitley take a set! E85 here I come!
DBMajik is offline   Reply With Quote
Old 02-25-2007   #8
Re: Injectors
No, you will still need a resistor box, resistors or an injector driver box. They are still a lower resistance injector than a normal saturated 11-16ohm injector, so more resistance would need to be keep in the loop to keep from burning up the injector drivers in your ECU. Who knows if they are really saturated injectors though. I don't trust Summits info 100%, the Ford Motorsport catalog doesn't mention if it's saturated or peak and hold, and a saturated injector of that large a size is quite unusual.
I wonder how well they are calibrated though. In the Ford Motorsport catalog, they sell matched sets of injectors that flow within 1% of each other and that type of injector is not available in matched sets.
Old 02-25-2007   #9
Re: Injectors
Ya you will still need the resistor box as these are still low impedance injectors.
Make sure they are in stock though Jet. I had put in several orders with companies who said they had them in stock, until I put in an order and a day later I get an email saying sorry, they are on backorder for a week. I ended up waiting a good 3 months for these until I finally gave up and just bought a set of PTE's.
Old 02-25-2007   #10
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: Injectors
I have a set of PTE's that I bought from Shane last year, they didnt have anything on them that showed them to be Ford injectors but I'm sure they are damn near all the same.
Although I am interested in buying up a set as well. I will need another 4 in order to run methanol this year. So if you find someone and anyone else wants to go in on a set, let me know.
Originally Posted by shoutbox
Old 02-25-2007   #12
Re: Injectors
Yes like I said above, sometimes slight machining is needed. Doesn't FIC machine the injector tips down a hair before sending them out now? Maybe PTE does the same. Anyone know for sure?
Old 02-25-2007   #13
Re: Injectors
It probably isn't even 5 minutes to ream the rail out a bit bigger.
Old 02-25-2007   #14
Re: Injectors
Exactly. Save 200 bux, but have to open up the hole in the rail. I'd take that trade off anyday.
Old 02-26-2007   #15
rst95eclipse
Re: Injectors
Since I'm running an anodized rail, reaming it out just isn't an option. Brian at PTE informed me that there is absolutely no need to drill out the fuel rail. To me, that alone is worth the extra $100. Good luck to you guys that are going to run them. If you need an extra rail (if you drill it out too far), I have a spare.
Old 02-26-2007   #16
Re: Injectors
You are reaming out the inside of the bungs so you won't even see it from the outside, it can stay anodized and look fine.
Old 02-26-2007   #17
rst95eclipse
Re: Injectors
Who knows. One day I just might dump in some methanol for shits and giggles. I'm aware that the stock rails will flow enough fuel. I just wanted the super cool ginormous rail with "Magnus Motorsports" etched into it. Plug and play saves me the hassle of reaming it and threading it for AN fittings. So, I waste time reaming my stock rail out and threading it. I'll have to buy a drill bit (I don't have something that large) and a tap with AN threading. Then, I'll have to anodize the rail. All of which cost money. I'm just guesstimating, but it might be around $50 in overall savings - which to me is worth not having to deal with it.
Ever drilled something out? It leaves scratches. Again, I'm anal on how things look and I wouldn't want to anodize the rail twice.
Old 02-26-2007   #18
Re: Injectors
How does REAMING something out in the inside scratch the outside? I was a machinist for 9 years, don't start.
You can just say that you paid some extra money for bling, don't try and rationalize it.
Old 02-27-2007   #19
Re: Injectors
OT:
i love my Super Cool Ginormous Fuel Rail. Cant wait to put the engine in and get some pics up of the entire setup.
Old 02-26-2007   #20
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: Injectors
See this is where you being so god damn fucking picky hurts you!
Run a stock rail, tap it out to accept NPT fittings and get a AN to NPT fitting. No drilling, just tapping, then ream out the injector bungs, take it to get it anodized for $10 and what do you know... just saved $300-$400 from using the stock rail which will flow plenty of fuel, and buying these injectors!
