Old 05-10-2007   #1
rst95eclipse
Bolts
I need two bolts that connect control arms to the rear subframe on a 95 GSX. One is that 10"er on the arm that the end link and shock connects to. The other is the arm that is the furthest back and connects higher to the subframe. Forget their names cause I'm not too knowledgable in suspension tech. The regular time and money figures. Thanks Nick.
Old 05-11-2007   #2
Nick G
Nick G's Avatar
Snow Storm Champion!
Drives: 94 v10 Ram
Re: Bolts
I would want you to look at picture
accentric bolt mb911314 $5.88 in stock
accentric washer mb911283 $1.68 in stock
washer ms450992 $0.30 in stock
nut mr130510 $2.18 in stock
bolt mb844522 $3.30 need to order
washer ms450993 $0.30 need to order
nut mf430123 $0.86 need to order
thank you!!
Nick
LUTHER BROOKDALE MAZDA MITSUBISHI
763-503-4695
nick.galbreath@lutherauto.com
http://www.facebook.com/#!/Luther.Auto.Dealerships
http://www.Lutherauto.com
Nick G is offline   Reply With Quote
Old 05-11-2007   #3
rst95eclipse
Re: Bolts
I dont know if you can post a pic like this one off your computer program, however this is a FWD rear end. All I could find, but it should give you the idea of where they're located. The two bolts I need are #5 and 8. I will need washers that are used since they were rust-welded, however I luckily got the nuts off so I won't need those.
Old 05-15-2007   #4
Nick G
Nick G's Avatar
Drives: 94 v10 Ram
Re: Bolts
wow I had the right parts
if you dont need the nuts we can take them off
let me know
thank you!!
Nick
763-503-4695
