Old 10-31-2007   #1
X Factor
The Newbie
Interested in some EVO breaks
I am interested in possibly picking up some EVO breaks... good condition!
2006 Mitsubishi Eclipse GT
X Factor is offline   Reply With Quote
Old 10-31-2007   #2
Re: Interested in some EVO breaks
I will clarify for Tim:
He is looking for some Evo 8/9 stock brakes, front and rear, including all mounting hardware, calipers, lines, and possibly rotors and pads if they are in usable condition.
Tim, you're going to have a harder time finding a rear set since a lot of the time people only replace the fronts. EvoMN and EvolutionM would also be great sites to check.
Old 10-31-2007   #3
X Factor
The Newbie
Woot. Thanks mang. Yeah i'm registered on both of those sites I think, I just figured i'd post here right away cause i'm at least somewhat familiar with the crowd.
SEX!
Oh also, from our conversation last night, I talked to another guy this morning/later last night about it a little and he has same wheel size as me with 35mm offset and he's putting his in soon, and he's confident that his will fit fine. Also, the rear does require a LITTLE bit of tweaking to make it fit in the rear, and front is direct bolt on, the guy who did them said a washer is perfect for the rear to fit, and you have to bend the dust shield just a bit also in the rear.
Apparently they make a pretty big difference also, according to the 1 guy that I know that has them done, heh. Also I for sure need EVO rotors, so if I can find some in good condition i'll need to buy some.
Thanks for the help Chris!
Old 10-31-2007   #4
Apparently it's not a hard conversion for the 00+ Eclipses, I wish it was a little easier for 1G's, I've been looking into to doing it myself. Should make a huge difference since the new Eclipses come with really small BRAKES.
Old 10-31-2007   #5
Have fun paying for Evo rotors and pads.
Old 10-31-2007   #6
here you go
http://cgi.ebay.com/ebaymotors/Lance...spagenameZWDVW
Old 10-31-2007   #7
X Factor
The Newbie
Are those in pretty good condition? They look dirty but I mean other than that for having 42k miles would they still be good if I had new pads?
Old 10-31-2007   #8
Calipers should be just fine after 42k miles. Its common for the '03 caliper paint to fade like that so you'll just need to toss a new coat of caliper paint on (if you care how they look).
Old 11-01-2007   #9
That caliper isn't faded, they're still shiny. MINE are faded, they're clearly dull but still bright red. Those front calipers were heated to the point the paint started to burn. I've seen pictures of stock Evo 8/9 calipers turning almost black because the paint was burned so bad, simply from heavy braking.
Old 11-01-2007   #10
X Factor
The Newbie
Brake related question so i'll just toss it in here, would it be worth doing stainless steel brake lines? The only benefit for me I think would be that i'd never have to worry about replacing the brake line ever... is there any other reason to do it?
Old 10-31-2007   #11
I assume hes just getting them for the Looks factor? Unless he plans to auto cross the car or what not.. but then buying nicer tires and suspension would come first I think.
Old 10-31-2007   #12
X Factor
The Newbie
Yeah it's like 50/50. I don't plan on auto x ever (with this car), but function of better breaks is a plus for me and it seems like something that would be fun and cool to do to the car.
There is basically a limited after market for my car and i'm looking for fun things to do. So far i've done intake, headers, exhaust, and coilovers. (big thanks to the guys that helped with the i/h/e!! <3) and other than getting a tune there isn't much else to be done yet with the 4G GT.
Old 10-31-2007   #13
How about a manual swap.
Brakes not breaks btw.
Old 10-31-2007   #14
X Factor
The Newbie
Re: Interested in some EVO brakes
Woooooooooooow I feel like a moron... sometimes spell check just can't save you I guess.
Old 11-01-2007   #15
mdost03
Sonic Champion!
Drives: VA STI
Or a turbo install
Old 10-31-2007   #16
What does your pig weigh?
Old 10-31-2007   #17
X Factor
The Newbie
I'm not sure exactly... 3600-3800 I think.
Old 10-31-2007   #18
the brakes will help it out and will look better also
Old 11-01-2007   #19
Yea I have them on my M. They definetely add to pedal stiffness and the braking is more responsive. Same goes for a clutch SS line, versus rubber.
Old 11-01-2007   #20
SS lines are a good idea as long as you're tearing everything apart already.
