Old 01-10-2008   #1
Headgaskets
I started with an OEM Mitsu coppersprayed with ARPs. I rebuilt my engine, the block wasnt decked but the head was, and used a Mitsu MLS headgasket. I fear now because the block surface wasnt decked, that the wetness I'm seeing at the headgasket area is due to that. Is there a stronger than OEM gasket I can use that will conform to an irregular surface? Like a solid copper gasket?
Old 01-10-2008   #2
Re: Headgaskets
The copper spray on a MLS gasket should take care of any surface irregularities, if it doesn't, you need to get the block decked. Did you put a straight edge on it and check for warping? You could always go back to a stock headgasket without copper spray(it doesn't need it), which will take care of most irregularities and can withstand a lot of abuse when coupled with ARP's cranked down tight. Most people don't need a metal headgasket.
Old 01-10-2008   #3
Re: Headgaskets
I still rock the stocker/ARP combo.
Old 01-11-2008   #4
Re: Headgaskets
I mdid copper spray the MLS lol. And I'll just go back to stock if there is ever a real issue, and if I ever make lotsa power I'll just o-ring the block hahaha.
Old 01-11-2008   #5
Re: Headgaskets
I am still running a stock head gasket and there is less space between cylinders on a 2.4l. You will be fine with a stocker. I do copper spray my stockers though, just cuz!
Old 01-11-2008   #6
v8klla
v8klla's Avatar
Re: Headgaskets
We copper spray the OEM's for mild upgrades. We are using the SCE ICS Titan in Kyle's talon with great results (copper gasket with Internal Combustion Seals / Essentially an O-Ring without a groove) at over 700whp. We have also used Cometic gaskets with Duplicolor high heat / ceramic 1200* engine paint as recommended by Cometic to provide a better seal on imperfect surfaces. We have yet to have a head gasket failure in a customer car (knock on wood), but we resurface almost everything!
Chris
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 01-12-2008   #7
92Laser
92Laser's Avatar
Re: Headgaskets
I guess its just luck of the draw with those copper head gaskets. Friend of mine had it fail around 580hp. The block and head were both decked so we aren't sure how it failed. Could definitely see where the exhaust made its way into the coolant passages though.
92Laser is offline   Reply With Quote
Old 01-12-2008   #8
Supa_dupa_man
Bimmer Guy
Supa_dupa_man's Avatar
Drives: ///M3
Re: Headgaskets
mine is copper sprayed with arps, and it holds just great, thats with n2o...
MMFTW
Supa_dupa_man is offline   Reply With Quote
