Old 02-25-2004   #1
sorionc
Guest
Tournaments Won: 6
Posts: n/a
Is it cool to switch an 1g awd 5speed turbo with the 1g fwd turbo 5speed or the 1g auto????? I'm guessin no auto but what about the fwd?
Old 02-25-2004   #2
The AWD/FWD swap would be ok, I think the auto ecu might not work so well for idle and coming to a stop. But I could be wrong.
Old 02-25-2004   #3
LightningGSX
Hellbound
I've never examined an auto ECU, but I would imagine they have different timing maps as well as other differences.As far as FWD/AWD there is no difference(that I have found) other than a resistor soldered on the board(r129 or r130 IIRC) that tells the MCU it's AWD, which seems to only remove the top speed limiter.
-Nulli Secundus-
Old 02-25-2004   #4
Jacek
Captain J-Sack
the maps for the auto ecu i believe are difference because of the autos comming with smaller injectors.
Old 02-25-2004   #5
-GSX-Falcon
Guest
Tournaments Won: 6
Posts: n/a
Thats only for 2gs right? I was under the impression that 1gs never came with a speed limiter.
And your right, fuel maps on a auto ECU are for smaller injectors and a slightly higher fuel pressure.
Old 02-25-2004   #6
auto ecus are completely different than manuals.
The timing maps, boost maps, everything is different.
The speed limiter issue is 2g only.
you'd be fine switching fwd 1g to awd 1g and back.
Galant vr4 and 90 ecus are different as well.
Old 02-25-2004   #7
-GSX-Falcon
Guest
Tournaments Won: 6
Posts: n/a
nite, im planning on upgrading my injectors and going with a MT ECU. Since the cams/timing is a little diff do you think i would absolutley have to change my cams? I heard that are not that much diff, just offer a little more low end at the cost of some high.
