Old 04-10-2008   #1
1993 1.8 SOHC starting issues
My bro's girlfriend just picked up this sweet ride!
When warm, the car starts just dandy. When cold, it has a hard time starting. Seems to turn over and over and after a while, sputters, then dies. Turn it turn turn it and sputters and dies. Once it is to this point, you can start pumping the gas pedal and it will run a little longer, then sputter and die. Then turn it over and over a bit more, pump the gas and it will eventually go.
Spark plugs, wires, battery, alternator have been changed already.
Injector issue?
Old 04-10-2008   #2
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Re: 1993 1.8 SOHC starting issues
ECU Coolant temp sensor is where I'd start. PossibleFPR leaking internally is another area I'd look.
Old 04-10-2008   #3
Yup, both good possibilities. Both were problems on my Laser.
Old 04-10-2008   #4
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
I have a fpr if you need it.
Old 04-10-2008   #5
+1
Old 04-10-2008   #6
Ooh my brother did mention that he thought the coolant temp sensor might be bad! I'll try that
