Old 06-16-2008   #1
Mark Leasure
Mark Leasure's Avatar
DSM Link and 1600CC injectors
I bought a car with DSM link and I’m going to convert it to E85. I'm a noob when it comes to DSM link. Is it capable of controlling 1600CC injectors? I have an extra set of 1600CC injectors that i want to use.
Old 06-16-2008   #2
Re: DSM Link and 1600CC injectors
http://www.mitsustyle.com/forums/sho...t=dsmlink+1600
Upper right corner of the screen, between new posts and quick links. There are a few threads even on this forum about dsmlink and 1600cc injectors, not to mention the www.dsmlink.com forums and www.dsmtuners.com
Old 06-16-2008   #3
Mark Leasure
Thanks for the information, I guess my laziness got the better of me. I need to change the registration on the DSM link to use their forum. I'm not a member yet.
Old 06-16-2008   #4
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
link can only control one set of injectors. But yea, it'll hold the one set of 1600s just fine
pics or gtfo
Old 06-16-2008   #5
Get on the DSMLink forums.
Old 06-16-2008   #6
In short, it works better with E85 than with regular pump. I'm still sorting out my TB issues, but I've gotten it to idle better than it did with the AEM. It just sucks when you can't find E85.
Old 06-16-2008   #7
Mark Leasure
Here is what i got when I tried to register:
"Sorry, registration has been disabled by the administrator"
I emailed them??? Will I get a responce?
Old 06-16-2008   #8
twack
It was a auto get over it
twack's Avatar
youl get a response it might take awhile, just email them you name and password you want and the number on your dsmlink.
-side note. will the stock fuel pump handle e85 and 1600cc injectors
Old 06-16-2008   #9
Mark Leasure
nope, dual 255l walbros
Old 06-16-2008   #10
You could just slap an inline walbro 392 in addition to the in-tank. But I like my dual Walbro in-tanks. I can almost here them over the exhaust. :-)
Old 07-17-2008   #11
Mark Leasure
What dead time values are people using for 1600cc on DSMlink?
Old 07-17-2008   #12
I just installed some PTE 1600s a couple days ago.
-53% global, around 450us dead time, but I have lowered my base fuel pressure to 40psi (2g)
Edit: I had to raise my idle a bit, with 280ish cams and 900rpm it would want to die sometimes because it dipped too low. Now I'm at 1050rpm idle and it's great.
Old 07-17-2008   #13
I can check my old settings if you need or send you the file.
I got my 1600s to idle mint.
Old 07-17-2008   #14
PTE 1600's on e85
-60 & 525 and 9% on my 50hz slider. Idles great.
Click on the link in my sig for an idle vid.
Old 07-21-2008   #15
Mark Leasure
Setup is complete, idle and part throttle is great! I had a failing O2 sensor that was causing tuning issues.
