03-09-2004
#1
Big Turbo Monster
Drives: GTS and E55
Anyone know of a yellow evo that cruises around wayzata Mitsu? On the way home, the Hopkins organized street racing clan ,HOSRC,(remy, Iceman, 92gstex, 92tsiawd84 and I) found an evo on 12 heading towards 494. We tryed racing him but it didn't seem like he wanted to race. All of a sudden, he floors it. Remy and I, driving next to him, took off after. He pulled ahead a little until my turbo started spooling and I started pulling on him. Once noticing, he grabbed the brakes. He slowed down to 40 on 12/394 (speed limit 65) and pulled over quickly behind the montero. Todd, standing out the Montero's moonroof, was trying to waive him over to race us as we were going slow also. Instead, he remained on the bumper of the montero going 40 and exited a few blocks after.
Cant wait until I get a logger and can tune this car, I am running rich.
7/25/09
03-09-2004
#2
Been there, done that.
Which turbo are you running? 20G or 60trim?
-brian
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Best 1/4 - 11.7 on 93oct
Best 1/4 MPH - 120mph
03-09-2004
#3
Business as usual
20g. His car is a laggy bitch now. Now his car is a top end car. Boost doesn't build till over 5000.
97 Viper GTS
03-09-2004
#4
i bet the evo owner was just driving home from work only to have you guys confuse him/scare him... lol, i think him flooring it was an act of desperation. lol, i dont know
Subaru Impreza STi
03-09-2004
#5
I walked an EVO about a month ago pretty well. running 17psi
I matched his acceleration with the car in 5th and then we went at it again and I put it in 3rd and that's when I walked him.
both were from a 55mph roll.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
03-09-2004
#6
Either he has a 1.6l Honda or he has a serious problem if he is not building boost until 5k with a 20g! He should see full boost by 3800. Does he have a major exhaust leak before the turbo or is his wastegate stuck partially open?
03-09-2004
#7
Big Turbo Monster
Drives: GTS and E55
when I get a logger and can tune, I will up the boost and lean it out more. I should have no problem walking him than. Looking at bartons old setings, he was running 3 more psi and was leaner than I am.
7/25/09
03-09-2004
#8
Big Turbo Monster
Drives: GTS and E55
there is defenitly an exhaust leak but I think it is after the turbo. Mike adjusted the wastegate before I put it on. It has a 10 cm housing though. THe exhaust leak makes it sound completely different than before.
7/25/09
03-09-2004
#9
what did he have to adjust to the waiste gate?
I got full spool at 4100rpms (but I have HKS Cams) so figure on stock cams that should be a few 100 rpms less.
Definetely do a boost leak test - car was dyno'd and then drove for 2-3 days when my rear diff seal failed. And then the turbo was taken off. And if I remember correctly even on the dyno full spool was around 4100rpms?
-brian
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
03-09-2004
#10
Big Turbo Monster
Drives: GTS and E55
he thought the wastegate was out/in to far I think. I don't remember though.
7/25/09
03-09-2004
#11
First off the Evo kid was a driver with new mitsu plates on. He was like 16-18 max and we had seen him out cursin, looking for a race it seemed. He might of been breaking in the engine which im thinking he was but, i question the responsibility of Wayzata kids and how the treat there cars and refuse to loose even if involes lying.
James car is tunned with a SAFC-I. Hes running on a S20g with a 10cm2 ech housing i thought....(correct me if im wrong james/john). They have no loggin data for the car the just lean it out a tit bit for daily driving and what not i belive. I to think they could get the thign to spool around 4k but not int'll they get a logger and cable.
03-10-2004
#12
Business as usual
Spool should not have much to do with tuning (unless you are going for 50 psi). You are right on the turbo, HRC 20g w/ 10cm housing. From what Brian was running on this setup, we can raise the boost about 3 psi and lean it out even more than now. We do not want to push it until he gets some sort of logger or dsmlink.
97 Viper GTS
03-11-2004
#13
problem solved, error in assembly/bolt length resulting in blown turbo to manifold gasket.
Let us know how it spools now w/the new 7cm in it  .
03-12-2004
#14
Big Turbo Monster
Drives: GTS and E55
It spools a little over 4000, maybe 4500. It still has an exhaust leak coming from the spacer plate. Too lazy to pull the turbo again to fix it though. I beat a BMW 745 last night and tryed to race a 3kgt. The 3KGT had exhaust, headlight covers and GTO on the back. I have seen his sometime before. He didn't want to race though. I was pretty mad.
7/25/09
03-12-2004
#15
What color was the GTO? there is a guy here at work that drives a black one with Chrome Rims. Looks tight as hell. But I haven't talked to him yet. (afraid somone will catch on to my bending of the rules of internet usage)
-brian
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
03-12-2004
#16
-brian
Sounds like the right one to me slow. It was black and looked very clean in the dark.
| Thread Tools |
| Display Modes |
Hybrid Mode
