Old 11-15-2008   #1
v8klla
v8klla's Avatar
MAP Spec Twin Disc Clutch Kits Just $949.99 / In Stock!
This twin disc clutch kit combines the same Quarter Master clutch we all know and love with our new MAP 7.25" twin disc flywheel! Our new billet steel flywheel is of the highest quality, includes a ring gear, and still costs less than other options on the market!
MAP 6 Bolt DSM Flywheel with QuarterMaster 7.25" Twin Disc Clutch
We have yet to reach the power limits of this clutch! It was previously used on our 700+hp 2g, and is still in our 800+hp talon and working flawlessly! We tried every other clutch you can think of, and nothing could hold the power!
This clutch also allows for faster shifting based on the reduced rotating weight and smaller diameter discs. You will be able to shift faster than you ever imagined was possible with your old single disc! The only downside to this beast is the engagement as it can be quite harsh until you get used to it!
Features
- Open Design Allows Clean and Cool Running
- Low Moment of Inertia (MOI)
- Lightweight
- Great Overall Performance and Value
Application Notes
Minor modification / grinding of the clutch fork is necessary with this unit. We can complete this for you at no additional charge, simply select the new OEM clutch fork option below!
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 11-16-2008   #2
blageo23
AWD4G64
blageo23's Avatar
Re: MAP Spec Twin Disc Clutch Kits Just $949.99 / In Stock!
This looks like a pretty good deal. I may have to pick on up!
1998 Spyder AWD
567hp
490tq
