Old 06-29-2009   #1
NTobler
Drives: 1991 Talon TSI
1991 5 speed Talon TSI AWD + free Ford Exploder
Hey guys, I'm trying to up my style a bit and go towards a 2g dsm. So FINALLY I got my car running and now I want to see what I can get for it. The car has 187,000 miles on it, but has been repaired and all the needed maintenance has now been done.
I just got done fixing
-The head was removed at some recent point and a few bolts either worked themselves loose or just weren't replaced,(thus missing all the lower intake mani bolts and had one broken exhaust stud) All of which have now been replaced
-Brand new starter
-The radiator was brown and brittle I advised to replace it, (once removed I noticed the top hose neck had cracked off, and was clamped past the break) So I put a brand new radiator in it
-the Injector seals were leaking on two injectors(replaced all injector seals)
-the knock sensor "existed" but the wire leads had been torn off, So I put a brand new knock sensor in it
-the Idle stop switch was not there, and the lead to it had broken off,(installed new spade connector)
-the coolant temp sensor wires had cracked/corroded/broken, re soldered new connectors and such,
-the transmission does not shift well into 1st gear, shifts fine in all others,
(Im about to put in an extended fork into the slave cylinder which will fix this problem)
MODS
Eco 3 16 g turbo
660 fuel injectors
255 fuel pump
2g hacked maf
SAFC 2
3" exhaust
MBC
ACT FLYWHEEL
ACT 2900 PP
AEM street disc.
GOOD
new rebuilt head and transmission-just flushed trans and replaced fluid with syncromesh.
2 new front struts
new upper strut mounts.
new front lower ball joints
new front outter tie rod ends
new u-joints
boost gauge and 3 pillar pod
new passenger side axle
new pioneer 6x9's in the back and rockford 4" up front
new Diamond Crystal Clear headlights in it
Looking for 2500 OBO NOTICE HOW I SAY BEST OFFER! IM A VERY MOTIVATED SELLER! I'M ALSO WILLING TO LOOK AT TRADES AS WELL. I WILL ADD CASH IF NECESSARY!
Shoot me a call or text any time of the day at 763-218-8078 or shoot me an email at Larsonn@augsburg.edu
Nick Larson
CLICK LINK FOR PICTURES http://www.facebook.com/Nick.theshit...8&id=598716948
NTobler is offline   Reply With Quote
Old 06-29-2009   #2
NTobler
Re: 1991 5 speed Talon TSI AWD
Here are my pictures http://www.facebook.com/Nick.theshit...8&id=598716948
Old 06-29-2009   #3
How about a link that works for people NOT on facebook?
Old 06-29-2009   #4
NTobler
Shoot, I thought that still worked for people not on facebook...How do I post pictures? I'm computer retarded
Old 06-29-2009   #5
Put them on Photobucket, then use the [*img*][*/img*] (without the *) code to put them here.
Old 06-29-2009   #6
NTobler
Pics are working now....I think
Old 06-29-2009   #7
NTobler
very motivated seller! Don't be scared to offer, the worst I can say is no.
Old 06-29-2009   #8
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Make sure you like 2gs before getting rid of your 1g nick. I was thinking the same thing until I actually drove one, and learned 6'4", 220lb guys don't fit too well in 2gs..haha
Old 06-29-2009   #9
NTobler
Yeah haha- I don't know....I'm just seeing whats out there right now...
Old 06-30-2009   #10
wants to be sideways...
123abc's Avatar
Drives: Loud cars
So according to your first post, there is nothing wrong with this car at all? Drive straight, all the shocks are good, brakes are good, everything works, no leaks, nothing? You fixed this thing up from when you first got it and made those topics?
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 06-30-2009   #11
NTobler
Correct...putting new tires on and dyno tuning today. The tranny grinding issue will be fixed today or tomorrow once I get out to map and buy a extended for for the slave cylinder.
Old 06-30-2009   #12
123abc's Avatar
Drives: Loud cars
Would you be interested in a trade plus cash for my 01 Stratus R/T?
Old 06-30-2009   #13
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Good to see you're putting this thing back together in good running form. I would be interested in taking a look at it for my friend.
-1990 Mitsubishi Cyborg 4WD-
Old 06-30-2009   #14
NTobler
123abc- let me see some pics any mods done to it?
come on and take a look at it for your friend! I'm not trying to scam or jip anyone! You can look at it as long as you want, run what ever tests you want! I don't want to fuck anyone over, because I know what it feels like first hand now.
Old 06-30-2009   #15
123abc's Avatar
Drives: Loud cars
http://www.mitsustyle.com/forums/sho...927#post294927
Most recent pics. 107k. I'm the second owner. Oil changed every 3k, recent trans and power steering flushes done. Will come with stock wheels and tires and no subs.
It has a few "mods" done to it. I cut the muffler off and have a cone open air filter on an aluminum adaptor.
Old 07-03-2009   #16
NTobler
Let me think about it, when would be a good time to see it?
Old 07-03-2009   #17
123abc's Avatar
Drives: Loud cars
Weekends probably. Sundays for sure.
Old 06-30-2009   #18
NTobler
Car now is getting a FMIC installed and a WIDEBAND...could be getting 272 cams and 1000cc fuel injectors running on e85 tuning it with a ds map....all will be done by the end of the week.
Old 06-30-2009   #19
twack
It was a auto get over it
twack's Avatar
why you keep droppping cash on it if your trying to get rid of it
Old 06-30-2009   #20
NTobler
I've already spend the cash on the parts- they're going to be here by the end of the week....just forgot to include them bro
