Old 07-14-2009   #1
mukapahnpy
Broken'In'Fail
mukapahnpy's Avatar
Drives: 99 GSX
Fuel Pump Woes
Can the fuel pump be broken if you can still hear it? I can hear the Walbro whine, but I don't get any fuel. I replaced the fuel rail, fixed a leak, cleaned up the spill but now there's no fuel. Any thoughts?
Old 07-14-2009   #2
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Re: Fuel Pump Woes
Clogged fuel filter?
Why did you replace the rail?
Old 07-14-2009   #3
mukapahnpy
Broken'In'Fail
mukapahnpy's Avatar
Drives: 99 GSX
Re: Fuel Pump Woes
Fuelab fuel filter, was new when installed. I upgraded the fuel system. Anywho, upon performing the fuel pump check with the female connecter by the firewall, there was a leak at the end of the rail. Retightened it and tried to run the pump again, i.e. to adj. base pressure. Now there's no fuel at all. Any thoughts?
Old 07-14-2009   #4
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Re: Fuel Pump Woes
Disconnect the fuel line at the pump cover and jump 12v right to the connector at the pump. If fuel comes out move up the line and disconnect the line at the fuelfilter inlet, check again, etc, etc
Old 07-16-2009   #5
mukapahnpy
Broken'In'Fail
mukapahnpy's Avatar
Drives: 99 GSX
Re: Fuel Pump Woes
It appears my DIY band-aid fuel pump assembly is not up to the task. The pump was pumping alright, right back into itself inside the tank. Going to drill the inside diameter of the 90 degree bulk head.
Old 08-05-2009   #6
mukapahnpy
Broken'In'Fail
mukapahnpy's Avatar
Drives: 99 GSX
Re: Fuel Pump Woes
The next time that I have to get back to the fuel pump assembly, I'm going to try some of that epoxy stuff. Probably better than JB Weld.
