Old 08-30-2009   #1
Chim55117
Drives: 2007 BMW 335i Coupe
New to the forum, and some questions.
Hey guys, I'm brand new to DSMstyle, but not to DSM's. Well, new in the aspect of learning to work on them. My brothers both have DSM's and have had them since I was pretty young. My oldest brother has a Kensington Grey 1992 Galant VR-4, which you should see coming out of Elite Autosport soon. My other brother, Daneatsv8's has a 1991 Galant VR-4 in Summit white, and a 1997 Eclipse GSX.
I'm the newbie youngest brother and have a 1991 Eagle Talon TSI 1G-A. Being 16 and having your first DSM is a great feeling. I'm situated in the Roseville area.
Long story short, after dropping in my new engine, everything seems to be running well with the exception of a few things.
1. There is a sucking noise coming from my intake manifold, not my intake with filter, my intake manifold. The "leak" isn't coming from the throttle body, I'm sure of that. I can't feel any air leaking out either.
Is that sucking noise normal?
That ties into my next question.
2. For some reason, my idle is stuck at 500 RPM. If I back in or back out the BISS, there is no effect. Is there something wrong with my TB? Or would it have to do with my intake "leak". I put leak like "leak" because I do not know for sure if it is one.
Thanks in advance.
Few picture introductions.
Fairly stock rebuild with all the supporting mods for a Evo 3-16G, which it is currently running.
Old 08-30-2009   #2
viridionplague
Re: New to the forum, and some questions.
sounds like you have a really big vacuum leak.
i was redoing my bov earlier and started the car without the vacuum line hooked up and the car would sit right around 500 rpm very roughly
there are i think 3 vacuum nipples in the injector valley and there might also be one on the back or under the intake manifold
Old 08-30-2009   #3
viridionplague
looking closer at the picture, i dont see a vacuum line for the bov, at the bov or the manifold
edit, it also looks like your turbo isnt bolted up?
Old 08-30-2009   #4
Wow a family of DSMs that is awesome.
I have seen your big bro's car at elite very nice car.
Good luck with your car.
Old 08-30-2009   #5
spinz4
spinz4's Avatar
Send a message via AIM to spinz4
Do you guys have a boost leak tester if not I would build one and test for any leaks on all the cars, lol.
Welcome as well!
spinz4 is offline   Reply With Quote
Old 08-30-2009   #6
Chim55117
Thanks guys, I'm going to check the vacuum caps in the injector valley. The line from the BOV is there, you just can't tell from the picture. The turbo is bolted on. The water lines are deleted.
Thanks for all your comments guys.
Old 08-30-2009   #7
x2 on boost leak test. clean 1g man!
Old 08-30-2009   #8
Boost leak test FTW.
Old 08-30-2009   #9
Whenever I've had major vacuum leaks like forgetting to hook up a line it always idles higher than normal, never below 1000rpm.
Maybe check airflow readings? Is that a 2g mas?
Old 08-30-2009   #10
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Welcome, I'm in the Roseville area as well. I live on ruggles off Lexington. Should see me around in my white 1gb gsx. I also agree with the boost leak test.
Old 08-30-2009   #11
jhaan_dude
jhaan_dude's Avatar
Drives: a car
welcome, LET THE MODDING BEGIN!!!
Old 08-30-2009   #12
4seasons69
4seasons69's Avatar
on my car running a gm maf when ever I've had a major vacuum leak my car would start run for a minute idling low then die
Old 08-31-2009   #13
Chim55117
Jhaan, that's your old EVO 3 16G on there. I'm the kid who bought it. Haha. That's a 3G 501 MAS on there.
Old 08-31-2009   #14
What injectors do you have? Are you using an AFC for airflow correction?
Old 08-31-2009   #15
TurboDomestics
TurboDomestics's Avatar
hes got 560cc injectors and an keydiver chip to compensate for both.
4G63 0, Charlie 3
Old 08-31-2009   #16
TurboDomestics
Well do a boost leak test when I come pick up that logger. And well get it to purrrrrr like it should.
4G63 0, Charlie 3
Old 08-31-2009   #17
Project2G
Semper Fidelis
Project2G's Avatar
Drives: 1997 Eclipse GST
Nice valve cover. Clean 1G.
Old 08-31-2009   #18
Constant_Project21
Drives: E36
That vc would look awesome on my car haha.
Old 08-31-2009   #19
Chim55117
Haha.... Just realized in this picture my turbo is not bolted to the manifold. It is currently right now, that was just an older picture of my engine bay.
Old 08-31-2009   #20
Constant_Project21
Drives: E36
Any news on that boost leak? I have a tester at my house if you need one (I will until wed that is), just pm me and we could set something up.
