Old 12-13-2009   #1
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
awd... not so awd
Well, that past couple days I've been noticing that my car is oversteering more than usual. It's noticeable that the rear wheels are spinning more than the fronts. At first I thought it was the front axles but they're not leaking or ripped. I haven't really gone out and had a fun time with the car because of this issue. I don't want to make it worse than I think it may be. Does anyone have any ideas to why it could be acting like this? I haven't changed the transfer case or the rear diff fluids yet since I've owned the car. I've only done the trans fluid.
ლ(ಠ益ಠლ)
Old 12-13-2009   #2
CarPsyco84
CarPsyco84's Avatar
Re: awd... not so awd
broken front diff and locked up Viscous Coupler? Usually when diff's break though, it grenades the tranny cause of all the gear parts floating around inside...
-When in doubt, Moar RPM.
Old 12-13-2009   #3
awd-drifter
'2of9'
hmm. also, if adds to anything else, when I do "slide" a bit "using" the rear wheels, there is a whining noise that is louder than usual (sound is coming from the rear).
ლ(ಠ益ಠლ)
Old 12-13-2009   #4
93gtpeater
Drives: cbr 1000rr repsol
Iam having the same problem. I changed the tranny fluid. It was nasty and the fluild has about 30 miles on it. There was a lot of metal flakes. But I still have the noise. But I think the noise is coming from my head. Try changing the fluid it helped with my car with awd issue.
Old 12-13-2009   #5
awd-drifter
'2of9'
for sure. I'm really hoping it's not a broken diff or anything. thanks!
ლ(ಠ益ಠლ)
Old 12-13-2009   #6
aaronspeed
Drives: 1991 Eagle Talon AWD
A bad bearing in the rear end will make the LSD to grab one wheel harder than another and also will cause your noise. Un-Bolt the drive shaft and you can rotate the rear tires and hear the bearing noise. If your fluid is low that will cause the same effect but the bearing is probably now damaged.
aaronspeed is offline   Reply With Quote
Old 12-13-2009   #7
GnArKiLl
GnArKiLl's Avatar
sounds like the vc going bad... easy fix dont even have to pull the tranny
03 Evo VIII
95 Talon AWD-wire tuck,6bolt,holset powered,E85
95 Nissan 240sx KA-T
93 Eagle Talon-5spd swap,wire tuck..SOLD
Old 12-13-2009   #8
95talonracer
95talonracer's Avatar
VC or Center Diff.
Amsoil Dealer
Old 12-14-2009   #9
desolate
91 TSi AWD
desolate's Avatar
Drives: red 91 TSi AWD auto
If it's operating in a rwd type of effect then most likely the center diff is broken.
Old 12-14-2009   #10
brando
Drives: gutlass
vc probbaly bad
Old 12-14-2009   #11
awd-drifter
'2of9'
hmm. are there any write ups on how to remove the vc or the center diff? I'm glad I'm off to winter vacation next week so I may have time to go under the car and inspect it.
ლ(ಠ益ಠლ)
Old 12-16-2009   #12
jrohner
jrohner's Avatar
Pull the cover off the tranny; remove the c-clip, and BB's (sometimes theres one, sometimes two); slide the VC off. You may have to tap on it to get it to slide off, but if you have to pound hard, you have some issue with the center diff. Make sure you have the e-brake OFF and all the tires off the ground, so there's not any load on the center diff splines.
Old 12-14-2009   #13
CarPsyco84
CarPsyco84's Avatar
Im sure there is transmission removal and disassembly write ups somewhere.
Old 12-15-2009   #14
awd-drifter
'2of9'
hmm...not so sure about removing the trans yet. it's basically my only car and i dont want to do that "big" of a job on it yet. Maybe next year, I will. I haven't had time to check it out yet, works been hectic! 100 tires in 10 hours! If I do remove the trans, most likely i'll have a new 2100 clutch kit by then.
ლ(ಠ益ಠლ)
Old 12-15-2009   #15
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Where do you work? I work at tires plus and its been ridiculous lately. Finally starting to slow down. We have done over 450 sets of tires in the last week!
-1990 Mitsubishi Cyborg 4WD-
Old 12-15-2009   #16
awd-drifter
'2of9'
Discount Tires here in IGH. it's pretty crazy...and the weather just makes it that much crazier.
ლ(ಠ益ಠლ)
