Old 03-16-2010   #1
Chim55117
Drives: 2007 BMW 335i Coupe
FS: 6-Bolt Block, Transmissions, 4-Bolt LSD, 14B
Disclaimer:
Due to the nature of these parts, the buyer understands that these parts will be SOLD AS IS.
Posted 3/16/10
1994 1GB Talon TSI Shell
Painted flat black, rough drivers side rear panel, no motor, transmission, t-case, or differential. Clean title. Asking
200.00 - SOLD
1994 6-Bolt Long Block
Pulled from a running vehicle (Eagle Talon 1G-B). Approximate mileage on the odometer is 180,182. Cold compression numbers all range from 125-130. Hot compression numbers were not taken. Consists of the head and block. Unknown if it has been rebuilt at any time in its life. Asking 425.00.
1991 5-speed manual FWD 1G-A transmission
Never tested, as we received the car non running from which this was pulled. Asking 200.00.
1994 5-Speed Manual AWD 1G-B transmission
Ran smoothly without any grinds between gears. Mileage on odometer at time of removal was 180,182. Asking 350.00. SOLD
1994 4-Bolt LSD.
Pulled at 180,182. Asking 350.00. SOLD
MHI 14B
Has minimal shaft play, unsure of whether it has ever been rebuilt. Asking 100.00
If you need anything specific, ask here! Pictures are available upon request.
Old 03-18-2010   #2
Re: FS: 6-Bolt Block, Transmissions, 4-Bolt LSD, 14B
just to let you know the engine can not be a 94 if it was a 94 it would be a 7bolt. it has to be pre 92.5
Old 03-18-2010   #3
jrohner
jrohner's Avatar
Yeah. Early 92 maybe? Or swapped at some point.
Old 03-18-2010   #4
93gtpeater
Drives: cbr 1000rr repsol
Do you know spline count on the all wheel drive tranny? Do you have a tcase that will come with it?
Old 03-19-2010   #5
Chim55117
Thanks Mark, the engine was swapped at some point.
93gtpeater - I do not know the spline count yet, the t-case is available, but for an additional fee.
Old 03-30-2010   #6
Chim55117
Bump.
Old 03-30-2010   #7
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
I will give you Junk Yard price for that 91 transmission unless you can tell me for sure that there isn't anything wrong with it.
But that is a steep price for AS IS and "Never tested"
Old 04-01-2010   #8
Chim55117
No thanks.
Old 03-31-2010   #9
johnson
johnson's Avatar
Drives: 90mitsu
Do you have an awd driver front axle?
Old 04-01-2010   #10
Chim55117
Actually, when we pulled the engine, the axle boot broke. Sorry!
Old 04-01-2010   #11
twack
It was a auto get over it
twack's Avatar
thats a $5 fix
Old 04-02-2010   #12
Chim55117
thats a $5 fix
Maybe. I'd rather not mess with it. The AWD transmission and LSD are pending to 123abc.
Old 04-05-2010   #13
Chim55117
Thread updated, shell price dropped! Someone come and get it or it goes to the scrapyard! 200, you tow it away!
Old 04-06-2010   #14
Chim55117
Bump. LSD and AWD transmission sold.
Old 04-12-2010   #15
Chim55117
Bump. Prices and sold items updated.
