Old 04-02-2010   #1
86starion2.6
Drives: 1986 starion esi-r
bov help?
i dont even know where to start. my problem right now is my hks rcing bov was sticking open and i couldnt boost over7 pounds at 3500rpms. this dude took it off and plated the pipe that goes over my vc and said it was fine cuz they came with no bov from the factory.... idk about this. o and i was running a maf and just an air filter, now theirs a maf on it. what do i do? buy a new bov? or keep it plated? helllp meee
86starion2.6 is offline   Reply With Quote
Old 04-04-2010   #2
mitsukid124
mitsukid124's Avatar
Drives: 97 eclipse gst
Re: bov help?
it would help to know the car and year?
my 2g has a stock bypass valve on it. idk if its same 1g to 2g but the bov is supposed to blow the air back into the intake because the ecu accounts for it. the only way you can run it without a bov or vent the bov to atmosphere is if you have link of some sort or a maf translator so you can control afr's so the air is unaccounted for through the mas or maf.
someone correct me if im wrong please.
mitsukid124 is offline   Reply With Quote
Old 04-04-2010   #3
Re: bov help?
If it's stock, you will have a hard time getting more than 10psi without hitting fuel cut, it's just how the 86 was designed. It doesn't need a BOV, but one never hurts as long as it's functioning properly.
Old 04-05-2010   #4
86starion2.6
Re: bov help?
yea i had a hks racing bov and i put a mas on my car and was still running the bov....but it was sticking open and not working right. its an old bov. and i couldnt boost at all and as soon as it wanted to boost it fell on its face. i took it off and plated it where the bov was and now it runs perfect... jessie at primo told me its okay but eventually would wear on the turbo. its got aftermarket hard pipes for intercooler and im running a 16g turbo with 2.5 inch exhaust straight piped to 3 inch tip and a different fuel pump so its not really that stock. its pushing just about 12 pounds and doesent fuel cut or anything. just dont wanna mess things up... and like i said it runs great without it.
Old 04-05-2010   #5
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Re: bov help?
If it bothers you, why not just pick up a 1g bov for $30, have a flange welded on (if there isn't one on there already), and take the necessary steps to properly install/plumb the bov (by that, I mean correctly hook up the vacuum lines and such). I'm not a conquest expert, very far from it, so I wouldn't know where to start, but I'm sure it's not terribly difficult.
Just my .02cents, if you're worried about toasting your turbo, then just put a bov on.
Old 04-05-2010   #6
86starion2.6
Re: bov help?
yea i would install it properly. but since im running a mas now i couldnt vent it into the atmosphere... i would have to re route it back to my mas wouldnt i? it runs good now i dont wanna mess around with it if its gunna make my car run like crap again
Old 04-05-2010   #7
86starion2.6
Re: bov help?
the starions came from the factory without a bov. but the stock turbo was only pushing prolly only 8 pounds.. not 12
Old 04-05-2010   #8
Constant_Project21
Drives: E36
Re: bov help?
If you re-route your bov back into your intake, you shouldn't have any issues with it running bad (again, my info is strongly based on 1g dsm's). When you vent your bov to the atmosphere with a mas, youre letting air that's supposed to metered, off to the atmosphere...therefore, car runs like crap. Just do it right, and shouldn't have an issue.
The conquest guys will have to chime in on what steps to take to using a mas, I'm guessing your intake doesn't have a spot to recirc, seeing as your car didn't have a bov stock.
Old 04-05-2010   #9
86starion2.6
Re: bov help?
yea i would have to customize the housing for it on my mas. you think it would be hard? and could i run any bov? or do i need a certain kind?
Old 04-05-2010   #10
Constant_Project21
Drives: E36
Re: bov help?
I'm not positive, again, no starquest expert. Maybe you could switch to a new mas for a conquest that uses a bov? I'm sure it won't be too difficult either way.
As for bov's, get one that works, and that can be recirc'd. That's about all you have to worry about. That, and whatever flange you have on there, cause that will narrow it down. If you have a greddy 2bolt style flange, you can just get a 1g dsm bov for cheap, and it will suffice for what you have as a set-up.
Old 04-05-2010   #11
86starion2.6
Re: bov help?
yea it is just a 2 bolt flange shaped like an eye. would a 2g dsm bov work? ive heard of people swapping the starion mas an installing a 1g dsm mas... know anything about that?
Old 04-05-2010   #12
86starion2.6
Re: bov help?
i wish some starquest guys would help me out haha my starion is my first turbo car and ive learned sooooo much and have done alot of work on my car.. but im still learning and dont understand some things..
Old 04-05-2010   #13
Constant_Project21
Drives: E36
Re: bov help?
I've heard about it, wouldn't be able to tell ya what work would be involved in swapping the mas though. 2g bov's suck, just get a 1g bov, they're proven to work. My car saw 24psi on a 16g, with a crushed 1g bov, and it never leaked on me.
Check out starquestclub.com, should find the info you need there.
Old 04-05-2010   #14
86starion2.6
Re: bov help?
24 psi on stock internals? id be afraid to boost that much on my stock internals. i wouldnt go past 13... idk maybe it could handle more. i have looked on starquestclub.com im still gray in a few areas about a 1g mas swap though. i guess i would try to keep the starion mass and just run a 1g bov if you think thats gunna work good.. not trying to spend 230 on a new one
Old 04-05-2010   #15
CarPsyco84
CarPsyco84's Avatar
Re: bov help?
Is the BOV you have adjustable? maybe it could be tightened? maybe its gummed up with oil and could just use some TLC? maybe its junk. Any BOV will work, but all the brands have their own flanges.
-When in doubt, Moar RPM.
Old 04-05-2010   #16
86starion2.6
Re: bov help?
yea its got the bolt and nut on it that can be adjusted.... i opened it up to take a look and it has the rubber insert and everything looked fine... idk its way old. but i would need a bov the can be recirc'd so that would be any bov?
Old 04-05-2010   #17
Re: bov help?
You can use a BOV on a stock car and not recirculate it. It won't really hurt anything. The main thing is to get it running right before modding it. With an 86, you have to be careful about hitting fuel cut. Sign up at starquestclub.com and ask as many questions as you can, they will help you get it all set up right before mods or with the mods you have currently.
Old 04-05-2010   #18
CarPsyco84
CarPsyco84's Avatar
Re: bov help?
Try screwing the adjustment shaft into the BOV some more to tighten it up. Some BOV can be recirculated and some can't. If you don't recirculate it, it's going to have issues dying when you let off.
