Old 08-29-2010   #1
Mwolf83
Drives: 91 Eagle Talon AWD, 02 WRX, 97 Civic Hatch
Part Out- 1G Performance part out feeler
Email me at Mwolf83@hotmail.com, which is the same email for Paypal. Email is the BEST way to reach me if you are serious about buying parts and don’t want to miss out.
I’ve spent the last 6 years putting this thing together and now is time to get out of the 1G money pit world and into the EVO world.
All Prices are somewhat negotiable but consider that all parts are just about new and are about ½ price or even less.
1991 Eagle Talon AWD 2.3L Part Out:
All Motor Parts and Bolt Ons have 1500 miles on them or less. Such as the COP setup was put on about 10 miles ago. Some things do look dirty but will clean up pretty easily.
Mods List:
Engine $2600 for block and head still assembled: (Sold)
Block $1750: 1500 miles on it (broken in with Royal Purple Break In Oil and tuned by Shane @ DB Performance)
Modern Automotive Performance 2.3L stage 2 short block
Wiseco 8.8:1 Pistons
MAPerformance Ultimate Duty Rods
2.3L Crank ($400 extra in cost of building motor)
New Mitsu Front Case
ACL Race Bearings
Felpro Permatorque Headgasket
ARP L19 Head Studs
Balance Shaft Eliminator
New Timing Kit
Head $1000:
Mild Port and Polish
Supertech Black Nitride 1mm+ Valves
Manley Valve Springs and Titanium Retainers
SBi Bronze Valve Guides
Fidanza Cam Gears
FFWD Connection Stage 2 Cams (Crower 280's)
Bolt Ons:
Precision SCM6152 w/"S" Cover 4" inlet- $400 (Sold)
MAPerformance -10 Oil Drain- $35 (Sold)
TiAl Wastegate- $125 (Sold)
Fluidampr Harmonic Balancer- $200 (Sold)
PWR Aluminum Radiator- $250
Slim-Line Rad Fans- $50 each (Sold)
Greddy Type-S BOV Powdercoated "Batman Black" from FFWD Connection- $110 (Sold)
Spearco FMIC w/ Stainless Piping- $400
ARP Exhaust Manifold Stud Kit- $40 (Sold)
ARP Turbo Inlet and O2 (Outlet) Bolts (3 of 4)- $10
Walboro 255lph High Pressure Pump- $50 (Sold)
Fuelab Prodigy Inline 1300hp Fuel Pump (Sold)
Fuelab -10 Fuel Filter (818 series Black)- $45 (Sold)
Fuelab -8 Fuel Filter (828 series Black)- $50 (Sold)
Fuelab -6 Fuel Filter (818 series Black)- $45 (Sold)
Earls Stainless Turbo Oil Feed Relocater Kit with Inline Filter- $40 (Sold)
Magnus Phenolic Intake Manifold Gasket x2- $20 each
SCE Copper Exhaust Gasket x2- $15 each (Sold)
Deatschwerks 1600cc Injectors (set of 4)- $200 (Sold)
Denso 660cc Injectors (set of 4)- $150 (Sold)
Fuel Injector Clinic -8 Fuel Rail- $75 (Sold)
Magnus SMIM w/ Velocity Stacks and 75mm Plate- $400 (Sold)
Wilson Manifolds 75mm Throttle Body w/ Jackson Auto Machine DSM Adapter Plate- $250
Slowboy Racing Exhaust Manifold (has spot for Tial 38mm wastegate)- $175
RNR 3" Turbo Back Exhaust- $350
JM Fabrications Sheetmetal Coil Bracket w/ coil pack- $30 (Sold)
Spark Tech Coil On Plug wired with 91-94 connector- $250
Gates Racing Radiator Hoses- $35 (Sold)
JM Fab 1G DSM Throttle Body to Accufab (75mm) TB Adapter- $35
Turbo XS High Performance Dual Stage Boost Controller (Missing switch)- $100
JM Fab Dual -10 Oil Deluxe Catch Can with Modded Valve Cover and hoses- $175 (Sold)
HKS 40mm Wastegate- $150 (Sold)
Stainless Steel Tubular T3 Manifold- $150 (Sold)
Forced Performance 4” Intake w/K&N Filter- $60 (Sold)
Driveline:
T.R.E. Built Transmission- $1100:
Double Synchro 2-4 gears
Welded Center Differential
RIP Grip Limited Slip Front Diff
ACT Street Light Flywheel- $150 (Sold)
Lightweight Flywheel (not sure of brand, may be custom made, as light as ACT Streetlite)- $125
ACT 2600lb Clutch w/ Street Disk- $180
Stainless Braided Clutch Line- $15
Prothane Black Urethane Motor and Transmission Mounts- $45 (Sold)
Extended Clutch Slave Plunger- $10 (Sold)
Engine Management and Gauges:
AEM Standalone Engine Management- $800
AEM/Kavlico 5 bar MAP Sensor- $75
2g Knock Sensor- $40
Apexi El Boost Gauge (Mechanical)- $60
Autometer Oil Pressure Gauge (Mechanical)- $30
Autometer 30psi Boost Gauge (Mechanical)- $30
Autometer Fuel 100psi Pressure Gauge (Mechanical)- $30
Autometer Water Temp Gauge (Electric)- $25
Haltech E6K ECU w/ Flying Lead Harness modded for 1G (Harness never actually hooked up)- $300 (which is way less than I paid for the harness alone) (Sold)
Wheels and Tires:
SSR 16x7" Wheels w/ Nitto 555r Drag Radials 225/50/16- $750
Chassis- $2000 (Paid over $1200 for the fuel cell and all fab work to have it mounted):
Only about 80K miles, no rust.
15 Gallon Summit Fuel Cell (mounted flushish with chassis, dual -10 feed bungs, stock fuel filler, and a custom dual -6 Walboro hanger that also has stock fuel level sender)
Under Hood Fuse Panel Relocated Under Dash
Painless Wiring 6 switch Switch Panel mounted in arm rest.
Heater Core Removed
Black Out Covers For Front Turn Signals
Headlight Conversion to H4 Replaceable Bulb
Black Wind Diffuser Covers
Dark Dark Tint 96%
Progress Lowering Springs
KYB AGX Shocks
Rear hatch area stripped down but have all panels
Brand New Shift Cables
Non Turbo Throttle Cable
Symborski Shifter Bushing Kit
Mach V Shift Linkage Bushing Kit
Short Shifter
4 Bolt Rear End
Extra Parts:
Pauter Rods (one had spun bearing and needs to be resized) w/ Ross 8.5:1 Pistons (sold together)- $400
ARP Regular Head Studs x2- $25 each
Vibrant Performance Billet Turbo Oil Drain Adapter- $10
Solid stock timing tensioner (works like BLE Solid Tensioner but uglier obviously)- $30 (Sold)
Lots and Lots of other stuff that I have in boxes at home, such as:
Power steering pump
A/C compressor
Three sets of cams with gears
Transfer case (23 spline) (Sold)
2 rebuild AWD transmissions for 1g
Bare 6 bolt block, etc….just ask
Feel free to send me an email on anything you want or want to ask if I have available. Will also start a part out thread on Mitsustyle.com shortly.
Mwolf83@hotmail.com or PM me on Mwolf83 on Mitsustyle.com. Will take Paypal (you pay Paypal fees), cash, check (will wait until it clears to ship parts), money orders, cashiers check.
Here are some pics and a walk around video:
http://www.youtube.com/watch?v=3TAaZ-idUBg
Mwolf83 is offline   Reply With Quote
Old 08-29-2010   #2
Mwolf83
Re: Part Out- 1G Performance part out feeler
A few pics
ID:	10550   Click image for larger version
ID:	10551   Click image for larger version
ID:	10553   Click image for larger version
ID:	10554   Click image for larger version
ID:	10556   Click image for larger version
ID:	10557   Click image for larger version
Old 08-29-2010   #3
Mwolf83
More
ID:	10560   Click image for larger version
ID:	10561   Click image for larger version
ID:	10563   Click image for larger version
ID:	10564   Click image for larger version
ID:	10566   Click image for larger version
ID:	10567   Click image for larger version
Old 08-29-2010   #4
Mwolf83
Even more.
ID:	10580   Click image for larger version
ID:	10581   Click image for larger version
ID:	10583   Click image for larger version
ID:	10584   Click image for larger version
ID:	10586   Click image for larger version
ID:	10587   Click image for larger version
Old 08-29-2010   #5
Mwolf83
More Still.
ID:	10590   Click image for larger version
ID:	10591   Click image for larger version
ID:	10593   Click image for larger version
ID:	10594   Click image for larger version
ID:	10596   Click image for larger version
ID:	10597   Click image for larger version
Old 08-29-2010   #6
Mwolf83
And Again.
ID:	10600   Click image for larger version
ID:	10601   Click image for larger version
Old 08-29-2010   #7
Mwolf83
Walk around of the car and starting it to show that it runs and idles great, even on a cold start up.
Old 08-30-2010   #8
LaunchHard
LaunchHard's Avatar
are you trying to sell the chasis as a whole or part it out?
Old 08-30-2010   #9
Mwolf83
As a whole, I have very little time off from work each week and I don't really want to be pulling all the tiniest little things from it. I would like to keep it a rolling chassis with the possible exception of the wheels and tires.
Old 08-30-2010   #10
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
how much for one of them awd trannys
Originally Posted by 311evo
Old 08-31-2010   #11
Mwolf83
PM'ed.
Old 09-01-2010   #12
szewczyd
Did you ever get the oil pump/cover/leaking issues resovled?
http://mitsustyle.com/forums/showthread.php?t=26866
Doug
http://www.nerdwurks.com/sig.jpg
szewczyd is offline   Reply With Quote
Old 09-01-2010   #13
Mwolf83
Yessir I sure, did. I got a new oil pump and gasket that fixed the leaking issues and I worked out a deal with Chris @ MAP to take care of any issues I would've had with them.
Old 09-04-2010   #14
turboimports
turboimports's Avatar
Drives: DSM and Mitsu history
Those 1600cc injectors require a driver?
Old 09-04-2010   #15
Mwolf83
Nope.
Old 09-10-2010   #16
Mwolf83
Bump for parts going fast!
Tags
1g part out, 4g63, awd, talon, tsi
