03-24-2011
#1
MAP's Evo X Exhaust Manifold Testing / Dyno Results
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
03-24-2011
#2
Drives: 17 Honda Accord
Re: MAP's Evo X Exhaust Manifold Testing / Dyno Results
I don't think I need to comment my modlist on this site but I will on the other forums. Unless you want me to Chris.
03-24-2011
#3
I think we got it.
03-24-2011
#4
Originally Posted by 311evo
I think we got it.
I figured as much  Exactly why i didn't post anything.
03-24-2011
#5
pictures of the revised manifold please!
#6
MAP Long Runner in front, followed by our Revised Long Runner and then FID.
P: 763-545-3800
03-24-2011
#7
Post it, I am sure not everyone has your mod list memorized. Copy/paste is easy
#8
Well I wrote it elsewhere...people enjoy giving me shit for sharing info apparently.
But if you want it here:
Mods:
Buschur Bullet Exhaust
UR Testpipe
AMS Downpipe
AMS IC
AMS UICP/LICP
Primo 3.5" intake
FP black - ported heat coated
Blouch 21psi WGA
Built Motor - AMS Spec JE pistons, Manley TT rods, Cosworth bearings, stock sleeves stock crank
Built head - Ported/polished, +1mm valves (supertech) w/supertech springs
GSC S2 cams
Baseline w/ported n Coated stock mani - obviously changed manifolds
DW 1400cc Injectors
MAP AFPR kit
BlaqOps Progressive boost double pumper
E70 fuel
ACT 6 puck w/ ACT streetlite flywheel
Magnus CMC
03-24-2011
#9
FLOSSEN
Drives: 2011 corolla turbo S
Great results! Im sure Dave is Happy!
T-rev still #1 and lovin it!!!
03-25-2011
#10
550whp DD tune that's so legit!
Great results, thank you for sharing! Boost curves look closer than dave had described, that is definitely a key aspect to this kind of testing. Dave sent me a bunch of the logs and timing looked identical across the first round he sent, I have yet to review the second round.
Pumped to see the MAP Rev2 tubular mani make its way into production, and as always more data is good data imho.
Originally Posted by turbotalon1g
03-25-2011
#11
^Like I said the boost curves I posted were just one run randomly from each to give an idea. There were definitely runs where boost was much closer.
03-25-2011
#12
ice shoes
Drives: 06' EVO MR
I assume FID and MAP are having a little manifold spat by the sounds of things...
What happened there?
03-25-2011
#13
FiD posted Scheides' manifold testing results all over EvoM.
#14
Wat?
03-25-2011
#15
Scheides posted some, but FID posted all the results that Scheides didn't really plan to post where they upped the boost and what not.
I am guessing that is what Kracka meant.
03-25-2011
#16
Among about another 10 threads FiD posted in and/or started which were all deleted shortly thereafter.
#17
Yea, we upped it a psi or two to try to match the psi that the car was running with the MAP exhaust manifold. That was after running it with no changes and it dropped a little bit of boost.
03-25-2011
#18
Which is another way to do the testing.
I don't think there is anything wrong personally with either way the testing was done.
I will say that if we tried to match boost on some of these manifolds the long runner from MAP would seem to come out on top as it dropped the most boost, but who knows.
One could go crazy trying to run the "perfect test". I don't think there is a perfect way to do it.
03-25-2011
#19
It's going to be different from one car to another also. It's been known that a halfway decent tubular manifold is worth 30-50whp over a typical cast style manifold for 5+ years though. It's been proven on Hondas, 240s, DSMs, etc.
03-25-2011
#20
nice thread tags
| Thread Tools |
| Display Modes |
Hybrid Mode
