Old 06-08-2011   #1
maperformance
Drives: EVO
Send a message via AIM to maperformance
Look at me!! Evo X catback exhaust System w/ Varex Muffler
This full 3″ exhaust system features a single 4″ diameter tip for a subtle look that exits on the passenger side. It is constructed entirely of 304 stainless steel for ultimate durability. It also features a v-band disconnect for easy installation and removal, and includes all necessary hardware and gaskets.
The Varex Muffler
VAREX mufflers combine both the design technology of the stock muffler and the performance muffler into one single compact unit. A sophisticated butterflyvalve mechanism is implemented to redirect the exhaust gas flow and vary be-tween the two.
For higher sound level, the exhaust flows are directed through the opening path and produces maximum power with a robust sound level (or the “sports car note”) and near-zero resistance. Whilst for lower sound level, the exhaust flows are directed through the chambered path (similar design with the stock muffler), and produces minimum sound level that gives you the best in-car comfort.
Angle of the valve is also controllable, which can be adjusted to stop at any point between sports mode and silence mode. This gives you further freedom to set the optimal sound level according to your desired preference.
Settings
Street Mode
Setting your Varex muffler in ‘Street mode’ enables lower sound levels and maximum discretion, as exhaust gases are directed through a chambered path as would a ‘stock’ muffler
Race Mode
For greater power output and sound level, exhaust gases are directed through the opening path and produce maximum power with a robust sound level (or the ‘sports car’ note) and near-zero resistance.
“Anywhere in between”
As the angle of the valve is infinitely adjustable, it can be adjusted to stop at any point between sports mode and silence mode. This gives you further freedom to set the optimal sound level according to your desired preference.
For more info on these items and more click here!
maperformance is offline   Reply With Quote
Old 06-08-2011   #2
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: Look at me!! Evo X catback exhaust System w/ Varex Muffler
Wire the switch into Tephra MAP switching to go from quiet to loud when you switch from normal to kill mode on your tunes...now that would be cool
Old 06-10-2011   #3
That is a fukin cool idea!
Old 06-10-2011   #4
Murlo26
Murlo26's Avatar
I thought so
Old 06-10-2011   #5
v8klla
v8klla's Avatar
Not a bad idea, they have an RPM activated feature as well apparently, I personally really like the key fob
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 06-10-2011   #6
Sparky2211
Sparky2211's Avatar
Drives: 2g DSM, 2008 Evo X
Video doesn't work.
1997 Eclipse GSX - Project car - 601hp/475tq
2008 Evo X GSR SSS - Daily Driver - 407hp/434tq
Sparky2211 is offline   Reply With Quote
Old 06-10-2011   #7
v8klla
v8klla's Avatar
Works on my end?
P: 763-545-3800
Old 06-10-2011   #8
"this video is private"
Old 06-10-2011   #9
v8klla
v8klla's Avatar
Fixed!
P: 763-545-3800
Old 06-10-2011   #10
Sparky2211
Sparky2211's Avatar
The keyfob is pretty slick!
