Old 07-12-2011   #1
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
3/S parts, trans t-case axles and more.
I have adjusted some prices. If you see anything you have questions about let me know.
For Sale: all my 3S stuff.
Stock 5 speed 25 spline trans. Needs a rebuild and the mid case replaced. I have a replacement mid case that is included. $400
5 speed 25 spline T-case with Quadco input spool and EK2 t-case brace. $500obo
5 speed 25 spline T-case, input splines ok but not new. $150
CUSTOM 5 speed 25 spline trans and 6 speed t-case. These two are a matched pair, will not separate.
Custom you ask? It's been modified to be the shortest gearing possible in a 3S. It has been modified to allow a 6 speed t-case bolt to the 5 speed trans. After that it uses a JDM 6 speed front ring and pinion and needs the 5 speed rear diff to match it. The net result is the shortest gears possible for a 3S. Why would you want short gears? Mostly for autocrossing. If you are interested and want more details, here's a link: This trans also has a Quadco output shaft and a Kormex front differential. Unfortunately it needs the ½ hub and slider replaced along with 2nd gear and the syncro too. Shifts fine otherwise. $1000
NA VICS manifold and a custom built box that allows the AEM EMS to control it. $50
IC setup with 12x24x4.5” PTE core, custom endtanks, and custom short route IC pipes. 2” hot side 2.5” cold side. It will probably not work on a car with A/C and you will need to redo the power steering cooler. Solid motor mounts required as well (included). Will not work with stock fans. Tial 50mm BOV included. $900
Stock TT axles. $30 each, multiple rear sets, one front set.
14" Radiator fan of doom! aftermarket 2 speed fan. Moves tons of air compared to a lot of aftermarket fans. $80 part number 3814, look at specs here: http://www.haydenauto.com/upload/Hay...ctric-fans.pdf
Old 07-27-2011   #2
MustGoFaster
Re: 3/S parts, trans t-case axles and more.
Was going through the garage the other day and found some additional stuff.
5 speed shift cables,
side Window glass
Window motors
front sub frame pieces
TT Front knuckles
1G front calipers and rotors
1G gauge clusters and some other random stuff like TT oil filter housings and miscellaneous engine brackets
