Old 03-02-2012   #1
1999Gst
Drives: 1999 Eclipse,
Help timing scare
So I have a 1999 gsx with a 92 6 bolt swap motor roughly around 10,000 on it has hks 272s and mls head gasket and arp head studs, being powered bye a evo316g. Car has been running great for months.
Now here's the problem, went to take car out today and I always like to do a walk around check tires oil,coolent,timing belt, ect... But the problem today was that when pushed on timing belt rear can shaft gear(closest to firewall) had about a 1/4 inch of movement when pushing down on middle of timing belt to check tension ? Now in the past mOnths I've never seen it do this? And the belt seemed a little lose over the gear I could kind of slip it off almost of the gear ? Is this just because the car was off ? The cam gear closest to front end was still tight had no movement and no play in it? Should I start it? Or take it apart and look at the timing tensioner? I've never seen a 4g63 belt do this , thanks for advise and any help
Old 03-02-2012   #2
Re: Help timing scare
Check ignition timing to see if thats still on. Also it may be your tensioner is messed.
Usually there is some play, when you start it it will probably pull tight, but make sure everything is lined up still before you attempt to start.
Old 03-02-2012   #3
I'd try spinning the motor over by hand just a bit and see if the tension come back.
Sometimes depending on what cams you have if the motor stops in just the right spot it can create what seems like more play than it should have.
Old 03-02-2012   #4
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
This
Converted to LS
Old 03-02-2012   #5
1999Gst
That's what I'm kinda thinking but just wanted to see of that was a common Dsm problem or not, I'll try spinning the crank and post the results , thanks for all the feed back
Old 03-03-2012   #6
Normal, a 3/s will do it bad enough you can almost skip the tbelt on the cam gear.
Old 03-04-2012   #7
1999Gst
Yea spun the crank by hand and tightend up, thanks for the info help!
Old 03-05-2012   #8
Glad to hear everything is ok!
Any takers on the car yet or end up deciding to keep it?
Old 03-05-2012   #9
1999Gst
Got a guy coming from chicago, but I think I might just do a E85 tune in the next month and keep it for he april cruze, what you doing with the S2k?
Old 03-05-2012   #10
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Haha S2k?
Just keep it and tune on e85! Are you going on the cruise?
Old 03-05-2012   #11
1999Gst
Haha S2k?
brad has a honda s2000, yea I'm going to and yes I want a nice tune and be ready for the cruise,
Old 03-05-2012   #12
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
I know Brad had an S2K that's why I laughed. I'm want to make the cruise too but just gotta get a few things done first.
Old 03-05-2012   #13
Haha had is the key word. I sold it on Friday. Car ADD ftw!
e85 and a tune would really wake the car up!
