Old 04-18-2012   #1
v8klla
v8klla's Avatar
MAP Built 2.2L EF3 Evo X 537whp 406ft/lbs
This bad boy just left the shop yesterday for its maiden voyage back home to northern Minnesota. With peak torque around 4000rpms and 537whp on tap I can only imagine how much joy this daily driver will bring to its owner!
MAP Stage 1 2.2L Shortblock
MAP EF3 Turbocharger
MAP 3.5" Intake
MAP CompGate40 O2 Eliminator Downpipe
GSC S2 Cams
GSC Beehive Valve Springs with Ti Retainers
Turbosmart Dual Port BOV
Turbosmart CompGate40 Wastegate
AMS FMIC
AMS Test Pipe / CBE
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 04-18-2012   #2
Re: MAP Built 2.2L EF3 Evo X 537whp 406ft/lbs
Sweet! What's the stage 1 2.2L comprised of? Sleeves or no sleeves? I'd think you'd need sleeves and stock crank for a 2.2L which makes me think more of your stage 2 (I tell people I have a stage 1.5 since I have stock sleeves but the ultimate duty rods).
Just curious Power looks fantastic...max boost only 24 though, this is e85 I assume? What fuel setup is on this beast?
Old 04-18-2012   #3
I thought the 2.2's had a custom size crank? You'd really have to open up the bore on a 2.0 crank to get 2.2L.
Either way, that's one of the most linear hp curves I've ever seen, that puppy doesn't drop off a bit on the high end. Nice work.
Old 04-18-2012   #4
v8klla
v8klla's Avatar
When you sleeve these you can go from 86mm stock bore to 88mm (2.1L) or 90mm (2.2L), add in the 94mm Manley crank and you get another .2L for a maximum displacement of 2.4L
P: 763-545-3800
Old 04-18-2012   #5
v8klla
v8klla's Avatar
It's actually got the Manley 94mm crank, stock sleeves. E85 yes, I believe it is a DW300 pump I'm not certain on the injectors.
P: 763-545-3800
Old 04-18-2012   #6
Interesting setup! I guess if it had a spun bearing this would be a decent way to go.
So there's no room for a 100mm crank (like traditional 4G63 strokers), or nobody wants one in favor of more rev-ability on the 94mm crank?
Old 04-18-2012   #7
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
ERL uses the 4b12 crank, which makes it a 2.3L. I think that is a 96/98mm crank though? I think.
So you can get a 2.5L 4b11 if you want.
However I'd personally pay a bit extra for the nice new Manley 2.2L crank as you can rev to 8500 safely
You could do this if you spun a bearing and your cylinder walls looked alright I suppose. Then you could hone them and get new custom pistons/rods for the crank. However if I were you if you have to take your motor out again I'd sleeve it. You already overbored your stock sleeves!
Old 04-18-2012   #8
v8klla
v8klla's Avatar
ERL uses a 97mm OEM crank with custom connecting rods and some Nissan rod bearings. We originally planned to do the same but then Manley came out with their 94mm billet crank and pricing was very similar with far fewer headaches lol.
P: 763-545-3800
Old 04-18-2012   #9
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
Has DW 1300's for injectors.
Converted to LS
Old 04-18-2012   #10
Murlo26
Murlo26's Avatar
Nice, great looking powerband!
Old 04-18-2012   #11
Impressive!
Old 04-18-2012   #12
That looks awesome! Looks like my 16g dyno chart but with +120whp.
Old 04-18-2012   #13
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
amazing. i'd like to have a ride in that!
ლ(ಠ益ಠლ)
