Old 05-07-2012   #1
Yiddie
Yiddie's Avatar
Drives: 98GSX
Serious Issue
WTF!?!? Did a boost leak test found out I had an air leak coming from my throttle body, Got new oem gaskets, fixed it and now my car is running like shit! Idles rough and when I rev it, it sounds like its missing and somehow magically now I have white smoke coming outta my exhaust manifold area and muffler really bad.... No idea how i could be burning coolant from just taking off my throttle body and the part that is attached underneath the throttle body.
Any suggetions....
Yiddie is offline   Reply With Quote
Old 05-07-2012   #2
Re: Serious Issue
Did you get coolant from the fiav in the throttle body when you took it off? Or hook something back up wrong?
Old 05-07-2012   #3
Yiddie
Yiddie's Avatar
Drives: 98GSX
Re: Serious Issue
Noi coolant got into the tb, and it seems like the longer it runs the worse it gets. Im not sure what could of got hooked up wrong to cause coolant to do that. just took off intercooler pipe and my throttle body thats it.
Old 05-07-2012   #4
twack
It was a auto get over it
twack's Avatar
Re: Serious Issue
did you separate the throttle body in half (take the bottom half off)?
Old 05-07-2012   #5
Re: Serious Issue
Yea he did
Old 05-07-2012   #6
twack
twack's Avatar
Re: Serious Issue
possibly pinched the gasket in between the two throttle body halves.
Old 05-07-2012   #7
Yiddie
Yiddie's Avatar
Drives: 98GSX
Re: Serious Issue
the part underneath had like an o ring gasket, which I didn't replace. But either way that coolant just recirculates. Theres no way it could get into the intake or make it get into the engine.
Old 05-07-2012   #8
Re: Serious Issue
If that section is leaking, where do you think that coolant is going? Directly in to your intake plenum! Which would be huge amounts of white smoke, makes way too much sense not to check out.
Old 05-07-2012   #9
Re: Serious Issue
Water injection y0!
I'd be pulling the tb off and double checking.
Old 05-07-2012   #10
twack
twack's Avatar
Re: Serious Issue
most times if you separate the throttle body in two, the gasket between the halves swells and usually have to replace it.
Old 05-07-2012   #11
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: Serious Issue
x2 I agree. I had a brand new oem one put in a fiav block off plate. Ran for only a few thousand miles. Took the plate off and the gasket wouldn't even sit in the old grooves with out bunching up somewhere.
Old 05-07-2012   #12
Yiddie
Yiddie's Avatar
Drives: 98GSX
Re: Serious Issue
Where did you get the fiav block plate?
Old 05-07-2012   #13
Yiddie
Yiddie's Avatar
Drives: 98GSX
Re: Serious Issue
I took off the 2 coolant lines going into the fiav or whatever its called. and I just connected them to a valve so they just recirculate. It seemed to fix my problem with the coolant but yet again that part is just pissing out air, I have a oem o-ring gasket coming. I really hope that fixes the air leak. Also with my new throttle body gaskets, The tb that connects the air hose is still leaking...
Old 05-08-2012   #14
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: Serious Issue
You asked where I got no idea if it would help your issues. So I assume you wanted it sorry
Old 05-07-2012   #15
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: Serious Issue
You can buy it I am not using it. Send me a pm
Old 05-07-2012   #16
Yiddie
Yiddie's Avatar
Drives: 98GSX
Re: Serious Issue
How would that fix my problem? Just the coolant issue?, Wondering how it was leaking into the intake tho. My issue im having still is that fiav pissing out air. I guess i'm hoping that new gasket will do the trick but I have doubts.
Old 05-08-2012   #17
twisted954
Possible Head Trauma
twisted954's Avatar
Drives: after suspension
Re: Serious Issue
I HAVE Bypass plates in stock at MAP...block off plates, I'm not sure about...shoot us a call if you need one...we can get the block off plates too...but I KNOW we have bypass plates
Faster than pushing...
twisted954 is offline   Reply With Quote
Old 05-08-2012   #18
Re: Serious Issue
What is the difference?
Blockoff plate = block FIAV and IAV/ISC?
Bypass = block FIAV and retain IAV/ISC?
Old 05-08-2012   #19
viridionplague
Re: Serious Issue
if you dont block off the ports from the fiav after rerouting your coolant lines. the bead inside the fiav wont heat up and plug the hole so you will always be allowing more air past the throttle blade than you want.
eventually heat will make its way to the intake manifold and then the throttle body to fix this but it will take a long time/
yea the block off plate replaces the lower half of the throttle body.
the bypass plate goes in between the 2 halves and still allows for ISC operation.
Old 05-09-2012   #20
Yiddie
Yiddie's Avatar
Drives: 98GSX
Re: Serious Issue
Sooo what do I have to do to fix my problem. Just get a bypass plate?.
My issue im having is im leaking air really bad from the fiav/isc? the part attached underneath the throttle body and if I hook up the coolant lines to it now I get coolant inside my engine.( which never had this issue before till I took it apart ha go figure right...) I have a oem gasket arriving tomorrow that odd shaped one, I'm having doubts that it'll fix the problem. I've tried sealant twice now and still just leaking pretty bad. Was thinking of just getting a whole new throttle body setup...
