Old 07-08-2012   #1
Blue_gsx
FS: 1G PArt Out...Lot of purple parts
Add 3% for PP or send as a gift.
Purple Tial 50mm Q Blow off valve, comes with box and flange- Sold
BNIB Purple Tial 38mm MVS wastegate-SOLD
BNIB purple Hallman Boost controller-SOLD
Brand new 1G JMF polished catch can with -10an fittings. Shaved and Power coated purple valve cover with -10an fittings welded on, Evo oil cap and -10an Push hoses with mr.gasket shadow series fittings. Everything was just bolted on the car and never used-SOLD
4inch aluminum intake pipe. powder coated Black frost comes with 7 inch K&N filter and 4inch to 3inch coupler and t bolt clamps. I also have a full 4 inch coupler if you prefer that instead-$165 shipped
Aeromotive fuel pressure regulator powercoated dormant purple and satin black to match the tial purple. Comes with fittings, bracket and fuel pressure gauge. The vacuum fitting has been tapped to 1/8npt since I was going to run pnuematic fittings-SOLD
More pics can be found here:
http://www.flickr.com/photos/bluegsx...th/7527851050/
Blue_gsx is offline   Reply With Quote
Old 07-08-2012   #2
Re: FS: 1G PArt Out...Lot of purple parts
omg purple. Alpha D just came.
Old 07-08-2012   #3
mondale
Drives: 1g dsm
Did your MBC come from Hallman with the one touch fittings installed on it? Does one have a bleed hole in it?
8.59 @ 158
mondale is offline   Reply With Quote
Old 07-08-2012   #4
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Haha goodhart ! Goosh if the prices weren't so steep, but fair d be alllllll over that hah the valve cover almost looks just like what I want ! Especially with the fittings...Did u get those welded on ? by who and where?
Old 07-08-2012   #5
Blue_gsx
No I ordered those. You have to drill a small hole on the side of the fitting to act as the bleeder.
Originally Posted by Alpha D View Post
Wait so is this an actual part out or just those few parts?
I still got a bunch of stuff to take off the car. But these are the few parts I had in boxes or was easy to take off the car.
They were welded on by a friend of mine who does this by trade. Very good welder and dsmer as well.
Old 07-09-2012   #6
Blue_gsx
I am also selling my Ecmlink V3 package. I never got to install the V3 in the car before upgrading from V2 a while ago. Package comes with-SOLD
91+ Eprom ECU-No leaking caps!
Ecmlink V3 package-Never installed.
SD Bundle which includes the Omni 4 bar Map sensor, GM AIT, pigtails and Aluminum bung.
Old 07-08-2012   #7
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Old 07-09-2012   #8
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
What color is the dsm ur parting?
Old 07-09-2012   #9
Blue_gsx
Blue
Old 07-10-2012   #10
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Is that an actual all blue 1ga gsx (no silver on the bottom), or was it repainted? What's the reason for parting it out? If its clean you should keep the body together :/
Old 07-10-2012   #11
Blue_gsx
Yes it is an all blue 90 gsx. Only talon's came with silver on the bottom. This is the original paint besides a few touch ups it got through out its years. I'm parting it out because I lost all interest in dsm's and I need the money to fund more camera equipment.
Old 07-10-2012   #12
Constant_Project21
Drives: E36
NICE, I had a brief thought that this was that same car! Shitty, Id love to have that color 1g, haven't seen too many of those. Didn't see your location, I actually made a thread about this color gsx a on dsmtuners a while back, which you replied to.
Old 07-13-2012   #13
Blue_gsx
Yes i remember the thread.
Old 07-13-2012   #14
Blue_gsx
Got some more stuff to list
More pics of the items can be found here:
http://www.flickr.com/photos/bluegsx...7630479523116/
PTE billet 6262 SP Journal Bearing and Oil Cooled T3/.82 with a 2.5 inch Vband outlet housing. It has been barely used. Turbo has about 25 passes at the track and a few hundred street miles from the first owner. I only got to mount it on the car. It is in great condition. I will also include the following:
-4an SS oil feed line
oil drain flange with gasket and -10AN Push lock fitting
brand new T3 stainless steel gasket.
SOLD
1G polished JMF Race SMIM with velocity stacks.Comes with bolts and brand new OEM intake manifold gasket. It was only mounted on the car-SOLD
Brand new Straight Line Specialties T3 manifold. Flanged for a Tial 38mm MVS. It was only mounted and never ran. Little surface rust on the turbo flange. This manifold is a work of art. I will include a OEM 4 layer exhaust gasket and a brand new T3 gasket as well-SOLD
Old 07-14-2012   #15
Blue_gsx
FPR and JMF are sold
Old 07-16-2012   #16
Blue_gsx
SLS manifold-Sold
Tial MVS-Sold
Old 07-19-2012   #17
Blue_gsx
Turbo and v band-sold
JMF smim-sold
Valve cover and catch can set up-sold
