Old 07-09-2012   #1
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Left Over Parts
Hey style i have a few left over misc parts that could maybe do someone some good. This is kind of a name your own price deal...im just looking fair low ball offers ha! That would be appreciated since most of this stuff is just taking up space.
-1G, 2G and Evo 3 O2 Housings SOLD! (30BUX)
-14B Turbo with some shaft play with manifold (stocker unported)
-2 Sets of 3 Inch Turbo Back Exhaust Systems (Both Custom) One Comes With a 2.5inch downpipe into 3 inch. The other Is 2.5 for the first feet then 3 inch all the way single piece exhaust...i cut it in half for storage would need to be welded in the middle
- 280 BC Camms (found my long lost Big boy camms...dont havr a build head for tjem you might so buy them...
-Long 2G Throttle Body inlet un hacked
-Short Style 2 Throttle Body Inlet un hacked
-L7 10 Inch Kicker Sub with small amp can separate
-No name brand 10 inch speaker in box (makes a great foot stool...)
-3 Eprom ECU's
-14Inch radiator fan pretty much brand new ran a few times....cant fit both 12 and 14 inch fan therefore selling 14inch fan. SOLD (20BUX)
-Evo 8 Oil cooler with 3.5feet of ss lines and i believe -6 or 10 fittings its two sizes bigger then a 6 i forgot its pretty big though. Got fittings for both ends regular size banjo bolts for the DSM OFH and fittings for the Evo Cooler (recommend flushing it before use just to be save) Lines could be sold separate with the fittings. I was thinking of maybe getting them welded onto my valve cover. Multiple usage for the set up.
I can send pictures of specific items if need be as well but yeah name your own fair price....
Thanks,
Old 07-09-2012   #2
dsm_talontsi
dsm_talontsi's Avatar
Drives: 91 Eclipse GST
Re: Left Over Parts
I need either the 2g o2 housing or the evo 3, whichever is in the best shape. Im creeping because of stock o2, time to upgrade. Also, will the 14" fan work with the stock 1g radiator, or is it too big?
dsm_talontsi is offline   Reply With Quote
Old 07-09-2012   #3
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Re: Left Over Parts
Should fit and both are in good shape one is just better then the other ...speaking evo 3 vs 2g just make an offer and u can test fit the fan I'm home after 9
Old 07-09-2012   #4
dsm_talontsi
Re: Left Over Parts
Text me, 612 876 8827.
Old 07-10-2012   #5
dsm_talontsi
Re: Left Over Parts
Thanks for the parts, hope I dont run out of wire on the fan tho. Dude must have been when he cut the wires, lol
Old 07-12-2012   #6
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Re: Left Over Parts
^ Your welcome and just a little bit . . .but if you bench solder and heat shrink you should be fine thats what i did. Turns out few wires to the ecu are cooked and my ecu probably is to had to cancel my tune
Old 07-12-2012   #7
dsm_talontsi
Re: Left Over Parts
Thats what Im going to do. How did that happen? Do you already have link in your ecu? thats would not be good. but man im sorry to hear that. Hey what kind of problems am I gonna have to go through getting this evo housing on? I have 3" dp, and a stock o2 housing gasket.
Old 07-12-2012   #8
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Re: Left Over Parts
pb blast your bolts ahead of time....get gaskets and new bolts just incase...it might be faster to even pull the manifold instead of leaving it on.... reason the last 14mm bolt closest to the block in the middle is a pain! Unless u have goos tools...
Old 07-15-2012   #9
mitsukid124
mitsukid124's Avatar
Drives: 97 eclipse gst
Re: Left Over Parts
Are any of the eprom ecu's for a 2g?
mitsukid124 is offline   Reply With Quote
Old 07-15-2012   #10
Re: Left Over Parts
I notice two of the ECU's say 90 AWD on them, is the third a 91-94 by chance? How much?
Old 07-15-2012   #11
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Re: Left Over Parts
I'd have to double check ill post uo before bed...and oh man its a stocker no chip burned or anything so just make a decent offer I'm litterally liquidating
Old 07-19-2012   #12
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Re: Left Over Parts
Bump!
Old 07-19-2012   #13
johnson
johnson's Avatar
Drives: 90mitsu
Re: Left Over Parts
Where are you located?
Old 07-24-2012   #14
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Re: Left Over Parts
Bloomington
Old 07-31-2012   #15
KcGsXrated
KcGsXrated's Avatar
Drives: 93 Talon Tsi
Send a message via AIM to KcGsXrated
Re: Left Over Parts
How much for the L7 and does it fit in the hatch with a decklid
~~DSK~~
Casey
93 Eagle talon Tsi fwd auto
KcGsXrated is offline   Reply With Quote
Old 08-11-2012   #16
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Re: Left Over Parts
Never ran it with the lid but if laid glad yes it'll fit and literally make an offer I just reinstalled it in my civic so ya could even listen if ya wanna!
Old 08-11-2012   #17
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: Left Over Parts
Looking for a 91-94 ecu? Did you check to see if that was one? Also need a 91-94 harness
Old 08-11-2012   #18
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Re: Left Over Parts
Those ecus are none eprom people so screw that...I mean you can buy em but yeah none emprom...and I have no harness.
Old 08-11-2012   #19
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: Left Over Parts
Is it a 91-94 ecu?
Old 08-13-2012   #20
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Re: Left Over Parts
I PMed you, can you reply please?
Style's automotive engineer
